11-11-2009, 02:45 PM | #1 |
Drives: Jeep SRT8 6.1L HEMI Join Date: Nov 2009
does anyone know what is the difference between LS3 and L99
11-11-2009, 02:47 PM | #2 |
Lightning & Thunder
LS3 = 426 HP
L99 = 400 HP LS3 = Manual Trans L99 = Auto Trans
Time is the only thing we really own. Use yours wisely.
11-11-2009, 02:50 PM | #3 |
Drives: 2010 Camaro SS/RS CGM M6 Join Date: Jun 2009
LS3 = No Active Fuel Management
L99 = Active Fuel Management
Vortech V-3 Kit, ARH LT's, Custom Exhaust, Aeromotive A1000 Fuel System, Custom Tune - 582 rwhp 533 rwtq 22" Modulare H2 Wheels, CF Hood, Trunk, Spoiler & Roof by Carbon by Design, Custom Steering Wheel from P-Factor Brembo GT BBK, Alpine INA-900, Alpine Type-R Speakers, Hurst Shifter, APR Splitter, Custom Quad Tip Diffuser CKS C1 Coilovers, Falken 452 Tires, 265/35/22 & 285/35/22, Custom Grille, AAC Halos, and much more to come!! |
11-11-2009, 02:50 PM | #4 |
LS3 is only on manual and has a racier cam and no active fuel management the L99 is only on the auto has a milder cam and includes active fuel management. LS3 has 26hp more than the L99 but doesn't get as good mileage.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
11-11-2009, 03:04 PM | #5 |
juggernaut
l99 is an ls3 re designed with a new valvtrain and cam for the autmatic to have AFM. which lowers hp but increases fuel economy.
the LS3 is just one bad ass motor with out AFM and is only available with the manual. |
11-11-2009, 03:04 PM | #6 |
Booooosted.
LS3 and L99 =
11-11-2009, 03:38 PM | #7 |
Camaro SL,UTs
Drives: 2010 Camaro SS/RS #16429 Join Date: Sep 2006
11-11-2009, 03:42 PM | #8 |
Booooosted.
11-11-2009, 03:43 PM | #9 |
Booooosted.
But the L99 is the far superior motor. EVERYONE here agrees to that.
11-11-2009, 03:46 PM | #10 |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
11-11-2009, 04:22 PM | #11 |
A ***'s Headache
Drives: Everything Join Date: Aug 2009
L99 Technical Specs
6.2 L V-8 Engine type: LS Series Gen IV Small-Block V-8 Displacement (cu in): 376 cu in (6.2L) Bore x Stroke (in): 4.06x3.62 Block: Cast-Aluminum with 6 bolt, cross-bolted main caps Crankshaft: Nodular Iron Connecting Rods: Powdered Metal Pistons: Hypereutectic aluminum Camshaft Type: Hydraulic Roller Valve Lift (in): .500" intake/ .492" exhaust Camshaft duration (@.050 in): 195 degree intake/201 degree exhaust Cylinder Heads: Aluminum L92 style port as cast w/ 68cc chambers Valve Size (in): 2.16 intake / 1.59 exhaust Compression Ratio: 10.7:1 Rocker Arms: Investment-cast, roller trunnion Rock Arm Ratio: 1.7:1 Recommended Fuel: 92 Octane Max Recommended RPM: 6600 Reluctor Wheel: 58X Balanced: Internal LS3 6.2L V8 Engine type: LS Series Gen IV Small-Block V-8 Displacement (cu in): 376 cu in (6.2L) Bore x Stroke (in): 4.06x3.62 Block: Cast-Aluminum with 6 bolt, cross-bolted main caps Crankshaft: Nodular Iron Connecting Rods: Powdered Metal Pistons: Hypereutectic aluminum Camshaft Type: Hydraulic Roller Valve Lift (in): .551" intake/ .522" exhaust Camshaft duration (@.050 in): 204 degree intake/211 degree exhaust Cylinder Heads: Aluminum L92 style port as cast w/ 68cc chambers Valve Size (in): 2.165 intake / 1.59 exhaust Compression Ratio: 10.7:1 Rocker Arms: Investment-cast, roller trunnion Rock Arm Ratio: 1.7:1 Recommended Fuel: 92 Octane Max Recommended RPM: 6600 Reluctor Wheel: 58X Balanced: Internal Biggest difference is the Valve Lifts, Camshaft Duration, and .005 in on the intake valve size. |
11-11-2009, 05:57 PM | #12 |
Madman
ARGHHHHHH
11-11-2009, 08:08 PM | #13 |
Drives: 2SS Camaro Join Date: Oct 2009
11-11-2009, 08:12 PM | #14 | |
Drives: BumbleBee, 67 Firebird,79 Porsche Join Date: Jul 2009
Unless you have your arm around your girl!
Ordered 9July09-2SS,RS,Transformer
1100 = Preliminary Order:7/13/09-NMGCZB 3000 = Accepted By Production Control-09/14/2009 3400 = Broadcast:09/14/2009 3800 = Produced:09/17/2009 2G1FK1EJ5A9147250 4000 = Available to ship 28Sept 4200 = Shipped-Rail-Detroit at 3AM on 5Oct, Departed for Miami, Ohio @ 3AM, arrived in Cincinnati, Ohio, 7 Oct 0749 arrived in Louisville Kentucky,at Kane Ave Tenn.@ 8:30PM,left for Wauhatchie, Tennesee 10Oct,Waycross GA10Oct,Jacksonville FL 11 Oct. 5000 = Delivered to the dealer 14Oct09 6000 = Delivered to the customer 17Oct09 |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 3652 | 08-17-2023 02:50 PM |
LS3 engine specifications | Tran | Wiki | 3 | 10-06-2010 10:56 PM |
Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
Big difference in trap speed in LS3 vs L99? | SubSolar | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 7 | 04-16-2009 02:42 PM |
L99 engine specifications | Tran | Wiki | 0 | 10-19-2008 11:40 AM |
