Old 03-15-2018, 08:09 PM   #1
buldog13
Drives: 2010 Camaro 2SS
Stainless works exhaust question
I sent this email to SW support but never heard back, I'm hoping someone here might be able to help me:
Hi,
I have a question about the Chevy Camaro 2010-15 Exhaust: 3" Dual Chambered System. I currently have factory headers, but eventually will be upgrading.
Is there just an adapter between the x-pipe and cats that I would need to change in the future to make it a full 3" system?
What is the sound difference between the chambered round and the turbo s-tube?
Thanks
buldog13 is offline   Reply With Quote
Old 03-15-2018, 08:50 PM   #2
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
There is a “power connector” I think is what it’s called, that replaces the 2.5” connector piece with a full 3” connector piece.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 03-15-2018, 08:56 PM   #3
buldog13
it is a connector piece though that can be replaced, the tapper down to the 2.5" isn't built into the x-pipe?
Old 03-16-2018, 08:02 AM   #4
2SScamaro2010
2SScamaro2010's Avatar
Drives: 2010 2SS M6
X pipe is separate from the pieces that neck down to 2.5”. I originally didn’t plan on getting headers and just ordered the factory connect cat back. Then the internet happened and I ordered headers one night but just used factory connect for those also. Some might argue but I don’t think I’m hurting anything necking down that 1/2” after the cats. I’m not putting down enough power to have issues.
Mods: SW Retro Chambered cat back, CAI cai black, APEX scoop and ww tank, RX catch can, APEX Skip-shift Eliminator, Hurst short throw, Speeddawg knob, Kooks 1 7/8 headers high flow cats, BMR trailing arms and toe rods, Livernois dyno tune, ZL1 grill and side skirts.WHP: 415 WTQ: 407
2SScamaro2010 is offline   Reply With Quote
Old 03-16-2018, 08:10 AM   #5
buldog13
Thankyou!
Ya I doubt it'll hurt anything unless you get into turbo/super. I might possibly put in a supercharger one day so want to be prepared in case.
Old 03-16-2018, 10:11 AM   #6
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Yea, I don't think that will hurt you at all with your current power level.
If you were to go ahead with a cam or go FI in the future then maybe that would be a good time to consider swapping it out to full 3", but even then it would be minimal gains.
This just happens to be how 90% (made that up) of the exhaust manufacturers for our cars design them, so you are definitely not alone
InFiD3ViL is offline   Reply With Quote
Old 03-20-2018, 07:37 AM   #7
TheInfamouSS
@LS.ACE
TheInfamouSS's Avatar
Drives: 2014 Chevy Camaro 2SS/1LE
I have actually had this same thing happen to me. Talked to Stainless Works and they were able to help me out. No need to fear.
I bought the Stainless Works 3" retro catback to the factory connections when I first bought the car because I liked how it made the car sound and figured if I was going to drive it I wanted it to at least sound good to start off. I had also planned on going twin turbo at that time and AGP said that exhaust setup would work fine. Ended up changing my mind and going the Supercharger route and it wasn't a problem at all.
If you decide to go long tube headers in the future by either Stainless Works or Stainless Power, all you have to do is get the headers that say "Performance Connection" and that will give you the piping to make the rest of your exhaust a full 3" from the headers back.
TheInfamouSS is offline   Reply With Quote
