Old 08-20-2017, 08:39 AM   #1
who-dat
Drives: 2011 1ss
Exhaust clamps
Need to replace the clamps that come with Speed Engineering headers today. I'm looking at a 5" lap joint at a local shop I can pick up. Anyone know if 5" is too large?
who-dat is offline   Reply With Quote
Old 08-20-2017, 10:13 AM   #2
xc_SS/RS
Drives: 2010 Camaro SS/RS
It's about 2" too large. Look for a 3" band clamp or a 3" lap joint band clamp for a better seal
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 08-20-2017, 11:18 AM   #3
who-dat
Drives: 2011 1ss
I've looked all over town for a 3" lap joint, but unfortunately nothing. I'll probably use a band clamp with RTV
Old 08-20-2017, 02:07 PM   #4
2SScamaro2010
2SScamaro2010's Avatar
Drives: 2010 2SS M6
I would think 5" would be to big. If you have amazon prime they have all different sizes on their website and it only takes a couple days to get your clamps. That won't help you out tho if you need the car put together today.
Mods: SW Retro Chambered cat back, CAI cai black, APEX scoop and ww tank, RX catch can, APEX Skip-shift Eliminator, Hurst short throw, Speeddawg knob, Kooks 1 7/8 headers high flow cats, BMR trailing arms and toe rods, Livernois dyno tune, ZL1 grill and side skirts.WHP: 415 WTQ: 407
2SScamaro2010 is offline   Reply With Quote
Old 08-20-2017, 02:45 PM   #5
Synner
Drives: cars
Not even close to being able to tighten and do anything.
Synner is offline   Reply With Quote
Old 08-20-2017, 02:54 PM   #6
who-dat
Drives: 2011 1ss
Well I changed the speed engineering clamps out with some 3" band clamps. I can still feel small puffs of air around the clamps. Any ideas what to try next? ...or is the small air puffs normal? Guess Ill end up ordering some high quality clamps
Old 08-21-2017, 01:55 PM   #7
onegoofydad
Drives: 2014 Camaro 2SS
Don't worry you are not alone. I have those clamps that came with it tighened all the way down over the slip fit, collector area.
I have puff's coming from a specific area, I can see how the clamp is not sealing if I look from the front.
I am considering just having them welded in place. I hate that idea from a removal and install perspective down the road though.
I have heard of a couple of options. 3" band lap joint clamps from summit, etc.
I honestly think some of this has to do with the angle of the slip fit to the existing exhaust system. For instance it appears that the headers maybe sit a little higher so the angle is slightly off which is also preventing the clamp from fully doing its job.
2014 Black/Black Camaro 2SS RS L99, CAI Intake, Speed Engineering LTH. Jannetty Tuned.
onegoofydad is offline   Reply With Quote
Old 08-21-2017, 02:02 PM   #8
who-dat
Drives: 2011 1ss
I ended up taking the clamps off and wrapping the pipes in exhaust tape really tight. Then used some 3" band clamps and it's finally holding.
Old 08-21-2017, 02:57 PM   #9
xc_SS/RS
I think I might do the same around my collectors! good idea
2010 2SS/RS
Old 08-22-2017, 03:06 AM   #10
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
When I put mine on the NPP system was about 2inches too wide to line up with the headers but was just fine with the cat deletes. I think the pressure the cat back is putting on the collectors is what makes mine have those little puffs out the front. OP, I went to advanced auto, got some 3inch band clamps that were 12 bucks a piece and got it as best I could.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
Old 08-22-2017, 09:26 AM   #11
WoodBoss
"Old School"
Drives: 2010 2SS L99
If you replace the supplied nuts and bolts with hardened nuts and bolts the Speed Engineering supplied clamps work much better, that is what I did.
WoodBoss is offline   Reply With Quote
Old 08-22-2017, 04:10 PM   #12
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
I bought a pair of these instead: http://www.ebay.com/itm/FITS-Catback...53.m2749.l2649
Doesn't look like it in the picture, but I was pleasantly surprised when they arrived and I discovered they were a polished stainless steel. From looking, you wouldn't know they weren't part of the kit. They fit perfect, and best of all, NO LEAKS!
go_go_gadget88 is offline   Reply With Quote
Old 08-22-2017, 10:45 PM   #13
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
I bought a set of these for use with my SE longtubes: https://www.summitracing.com/parts/s...00-1/overview/
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 08-23-2017, 05:19 AM   #14
flashpuppy
Drives: 2010 SS
Had these on my 06 GTO with SLP longtubes and Loud Mouth II. Could never get them to seal up and tighten well. Wound up welding the whole thing. Glad you are having success with those.
flashpuppy is offline   Reply With Quote
