Old 06-26-2017, 05:44 PM   #1
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
ZL1 1LE wheels offset confirmation (from a new owner or dealer)
Now that the 1LE's are arriving at dealers, can someone with access to one get a confirmation on the F and R wheel offsets? I've heard rumours online, but no one can actually confirm. GM parts departments have them listed at +50et, which is obviously wrong.
Would be greatly appreciated!
seanblurr is offline   Reply With Quote
Old 06-26-2017, 06:08 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
I THINK This is right:
Stock 1LE is +20 & +43
Old 06-26-2017, 06:10 PM   #3
JeromeS13
Drives: 2017 1SS/1LE
He's asking about the ZL1 1LE. Not SS 1LE.
Old 06-27-2017, 10:57 AM   #4
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Yep, ZL1 1LE, not SS.
Old 06-27-2017, 11:54 AM   #5
OminouSS
OminouSS's Avatar
Drives: Red Hot track candy
Beat me to it.
Mr. W, are you willing to take a wheel off for us?
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
OminouSS is offline   Reply With Quote
Old 06-27-2017, 12:03 PM   #6
ChadFarr
Instagram: @SSAVAGEVERT
ChadFarr's Avatar
Drives: 2016 SS M6 Vert
I think he understands the question is about a ZL1 1LE, and not SS 1LE. The ZL1 1LE comes with 19" wheel, which could in fact suggest a +50 ET to compensate for a wider wheel with smaller diameter.
2.9L Whipple | Compstar Rods, Diamond Pistons & GPI Cam | Mantic Triple Disc | Corsa Performance Exhaust | DSX Aux Pump | LT4 Fuel System | BMR Lowering Springs | ZL1 OEM Conversion | 360 Customs Built | And More!
Click & Follow My Build
ChadFarr is offline   Reply With Quote
Old 06-27-2017, 12:42 PM   #7
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
I dont think you understand offsets correctly. Offsets don't play a role at all in diameters of the wheels.
From internet rumours, it appears that the offsets may be similar to the z28 wheels, at least on the front 19x11 +11et, but I can't get this confirmed. I have yet to hear anything about the rear 19x12.
Old 07-01-2017, 10:16 AM   #8
Tachitup
Tachitup's Avatar
Drives: 2020 ZL1 1LE M6; previous 2018 ZL1
ZL1 vs. ZL1 1LE Wheel offset
Does anyone know the offsets of the ZL1 1LE wheels? I know they are 19 X 11 on front and 19 X 12 on the rear but would like to know the offsets.
I know the ZL1 (non-1LE) are the same size and off set as the SS 1LE: 20 X 10 @ 20 mm and 20 X 11 @ 43 mm.
I appreciate the information.
Thanks !
Tachitup is offline   Reply With Quote
Old 07-01-2017, 01:38 PM   #9
tnspd
tnspd's Avatar
Drives: 18 Camaro ZL1 1LE (WILSON)
I would like to know the ZL1 1LE off set as well. I got a ZL1 1LE shipping to me any day now and I want to have DD rims and keep the OEM for Track days.
tnspd is offline   Reply With Quote
Old 07-01-2017, 10:14 PM   #10
OldJedi
Use the Force
OldJedi's Avatar
Drives: 2015 Corvette Z51, 2018 Porsche GTS
Send a message via AIM to OldJedi
MMR Wheels makes several designs that fit the ZL1 and 1LE that will work well on your car as a daily driver. You can also check in the Parts For Sale sub-section to see if anyone has ZL1/1LE rims for sale.
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
Old 07-02-2017, 02:06 AM   #11
PinHead
Drives: Duramax
Thanks !
Here's the info on the wheel finder for the 2017 (as 2018 not out yet)
2017 Chevrolet
Camaro SS
Here are some options that fit your vehicle. Keep in mind, choosing one of these wheel options may require a different tire size.
FRONT
20" (+0)
21" (+1)
22" (+2)
REAR
20" (+0)
21" (+1)
22" (+2)
PinHead is offline   Reply With Quote
Old 07-02-2017, 08:16 AM   #12
Tachitup
Tachitup's Avatar
Somebody please take their ZL1 1LE wheels off and take photos of the offset specs. Many thanks !
Old 07-02-2017, 09:35 AM   #13
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Good luck with the off-sets....Is there no vendor that makes a similar wheel for the ZL-1s?
I'm sure it will be a close fit....but just bear in mind the struts are different on a 1LE (smaller diameter)....The overall height and type of tires is important....The offset needed for a 19" wheel would be different than a 20" tire and wheel depending on the spring perch, ride height, and strut diameter and location...
...Good luck. But personally, I would let an aftermarket vendor work out the specs for each wheel and tire size for a custom off-set....
Good luck, and don't rush into anything.
Old 07-02-2017, 09:49 AM   #14
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I'd be happy to take some images/pictures of wheel offsets...but unfortunately, I won't have the time to do so until after the 4th...and even then - I've got to check and see if my garage jack will even fit under this thing.
