Roto-Fab
Old 06-28-2015, 09:47 AM   #1
Cayman
Drives: 2010 Camaro SS
LSA/ADM results
LSA kit with 2.75 sc pulley, #65, zl1 pump/adm fpcm, ls3 conversion, headers and 3" exhaust. Dyno results: 499 hp with 8lbs boost. I went with all the recommended upgrades except the heads. My goal was 550 hp! :(
Cayman is offline   Reply With Quote
Old 06-28-2015, 09:53 AM   #2
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
My LSA blower got me 650 Rwhp on a auto. But we cranked it up to 14lbs.
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80
“1360 Rwhp 1225 Rwtq 25 lbs of boost”
Scuzz is offline   Reply With Quote
Old 06-28-2015, 11:21 AM   #3
Cayman
I forgot to mention the BTR stag 1 cam! Curious, with all these upgrades, does it appear to be low? Thanks
Old 06-28-2015, 11:42 AM   #4
Scuzz
Scuzz's Avatar
My pulley combo was a 2.50 and a 8.66, which resulted in spinning the blower at just under 23k rpm. This in turn made 14 lbs on my set up. I've heard 1 lbs of boost is about 20 hp. You are 6 lbs less then I was, so (6x20 = 120). This would put you in the ball park if you cranked up your boost, so I would say it's your pulley choices.
I am no expert on the subject, but it seems a good starting point.
Old 06-28-2015, 11:53 AM   #5
Unreal
Drives: 2006 Z06
Tune good? Took decent timing? No leaks? Intercooler pump working and all air out of system? Correct and good plugs? Belt on properly so no slip?
If everything mechanically seems good, and tune seems good, time to pulley down.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 06-28-2015, 11:54 AM   #6
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
What were your starting rwhp and torque? How many miles on the engine? Is yours and LS3 or L99?
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 06-28-2015, 11:59 AM   #7
Unreal
Drives: 2006 Z06
LS3 conversion would indicate an auto.
Nick
Old 06-28-2015, 12:19 PM   #8
hammdo
hammdo's Avatar
Didn't see that. BTR also makes vvt stage one.
Thanks!
-Don
747 RWHP 794 RWTQ
Old 06-28-2015, 02:08 PM   #9
smokum
smokum's Avatar
Drives: 2010 2ssrs
If everything checks out ok i would say its in the tune.
smokum is offline   Reply With Quote
Old 06-28-2015, 02:31 PM   #10
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
For sure! Should have made much more power
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 06-28-2015, 03:53 PM   #11
ADM PERFORMANCE
Drives: Anything I want
-Don
Hammdo car is a great comparison here - Hammdo what was your power?
Hammdo what was your boost again?
Not at the shop today(SUNDAY FAMILY TIME).
ADM PERFORMANCE is offline   Reply With Quote
Old 06-28-2015, 04:12 PM   #12
Cayman
Thank you all! I'll answer all questions here!
I have the BTR PDS Stage 1 cam (recommended).
K&N cai
Inter cooler system circulating and full
Tom Wong (tuner), Vanc WA said timing was good
Iridium TR7IX gapped 38-40
Belt tension is slightly above top indicator mark, will replace with smaller belt.
550 original miles on car/engine
See Dyno attachment
Thank you
Old 06-28-2015, 04:18 PM   #13
Unreal
Drives: 2006 Z06
Mustang dyno is part of it. If you want big numbers go throw it on a dyno jet. Could easily be 530-550rwhp on a dynojet.
Nick
Old 06-28-2015, 04:23 PM   #14
hammdo
hammdo's Avatar
~570 rwhp, 510 rwtq , 6 psi boost, stock pulleys. I have ported ls3 heads, dod delete, and a ss1 VVT cam.
Those were the final numbers after the VVT was tuned.
And yes Sunday is family time!
-Don
747 RWHP 794 RWTQ
