TireRack
Old 08-12-2014, 12:21 PM   #1
WheelmanSS
Logic is dead
WheelmanSS's Avatar
Drives: 2010 Camaro 2SS/RS
Send a message via AIM to WheelmanSS
Snap goes the Chassis Brace - thoughts?
Hey yo,
After hearing some odd creaking noises coming from my car after going over speed bumps or quick and steep inclines, I crawled underneath my car.
I was surprised to see that my Hotchkis max chassis brace snapped at the weld at the front passenger side connection point in my car.
I'm not terribly upset about it, but I figured this would be a durable upgrade suspension piece. Oh well.
Before I make any changes/replacements, I wanted to pose the question: Do I really need the chassis brace?
My suspension setup is already pretty solid. In addition to the Hotchkis max chassis brace, I have a slew of Pfadt parts:
- Pfadt solid subframe mounts
- Pfadt trailing arms
- Pfadt tie rods
- Pfadt ZL1 front and rear sway bar conversion
- Pfadt adjustable coilovers
I'm thinking of just ditching the chassis brace, and replacing the tunnel brace (since the stock one was removed when i installed the chassis brace).
Thoughts?
2010 Camaro 2SS/RS (LS3)
573 RWHP 498 RWTQ
- Vortech V3 Supercharger
- Kooks Stepped Headers, Magnaflow 16580
- Suspension by Pfadt, Hotchkis.
2007 Trailblazer SS- Sold
2001 Trans Am WS6 431 RWHP 408 RWTQ - Sold
1994 Camaro Z28 - Sold
WheelmanSS is offline   Reply With Quote
Old 08-12-2014, 12:36 PM   #2
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
Makes you question whats going on if the brace is breaking?
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 08-12-2014, 01:23 PM   #3
WheelmanSS
Logic is dead
WheelmanSS's Avatar
Anyways, let's get technical!
573 RWHP 498 RWTQ
Old 08-12-2014, 03:08 PM   #4
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
The max chassis brace was primarily designed for keeping the rear cradle stable. The Pfadt subframe mounts you have are already doing that. I'd ditch it. (Not literally, it is still an expensive piece that could be easily repaired and resold). Pass it on to the next guy who doesn't want to run solid rear mounts. The weld probably just received a shock load it couldn't handle due to the subframe already being solid mounted.
2012LS3VERT is offline   Reply With Quote
Old 08-12-2014, 04:47 PM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
If you're not racing the car on a track, then the benefits of a chassis brace (or subframe connectors) on a street-driven car would be fairly minimal. However, if you bought the brace new, then I would definitely contact whoever you bought it from and inquire about a warranty replacement.....depending on how old it is. Just my .02 cents!!!
Old 02-19-2015, 03:45 PM   #6
WheelmanSS
Logic is dead
WheelmanSS's Avatar
Bumping this up. I have been out of the game for awhile and haven't really touched my car in over a year.
I think when I bought the Hotchkis max chassis brace, I ditched the stock tunnel brace as part of the kit.
If I remove the Hotchkis setup, what do I need to replace, if anything?
573 RWHP 498 RWTQ
Old 02-22-2015, 12:20 PM   #7
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Either get a new OEM tunnel brace or there are some vendors on this site who offer billet aluminum.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 02-22-2015, 02:58 PM   #8
Dan@Hotchkis
1
Drives: Whatever is available!
I'd love to talk to you about the brace and possibly getting it back so we can see if we can determine what happened for a possible warranty. Just as a quick question could you clarify whether the weld failed or the material surrounding the weld? Please PM me or e-mail me at dan@dtmracing.us at your earliest convenience please.
Dan@Hotchkis is offline   Reply With Quote
Old 02-22-2015, 05:32 PM   #9
revived
Vrrrm.
revived's Avatar
Drives: 2011 2SS/RS LS3
Durable for tracks not everyday driving and speed bumps...
revived is offline   Reply With Quote
Old 02-22-2015, 08:10 PM   #10
L99CAMA2011
L99CAMA2011's Avatar
Drives: One of the baddest handling Gen 5s
Z28 doesn't have a brace and it kicks a $$ go figure.
L99CAMA2011 is offline   Reply With Quote
Old 02-22-2015, 08:34 PM   #11
The_Blur
Moderator
The_Blur's Avatar
Drives: 2018 Harley-Davidson Street Bob
Send a message via AIM to The_Blur
I think Hotchkis could really use some pics.
RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
Operation Demon//Buy at Invoice//RACECARWEAR
RESPECT ALL CARS. LOVE YOUR OWN.
warn 145:159 ban
The_Blur is offline   Reply With Quote
Old 02-22-2015, 09:52 PM   #12
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Thoughts?
Sounds to me like a bad weld, not the brace.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 02-22-2015, 10:56 PM   #13
ZWA SS
BowtieBelle's SS
ZWA SS's Avatar
Drives: 2010 Camaro SS
I would think so too.
At least it would be an east fix, or check warranty with the rep above.
OP, if you need an OE tunnel brace I have a couple.
ZWA SS is online now   Reply With Quote
Old 02-23-2015, 12:00 AM   #14
Avalnch
Avalnch's Avatar
The Hotchkis Max Chassis brace makes a real world difference on the Camaro. It does tie the left and right sides together and makes the chassis a lot stiffer.
Prior to installing my chassis brace, when I back out of my (slightly elevated) drive way at an angle, you can feel the car flexing as each tire goes from the driveway to the roadway. After the brace, when backing out, the car definitely has less flex when backing out at an angle. I can feel the car almost tipping as it balances on the front and rear opposite tires. Much like if you take a rectangular board and place it diagonally across two uneven surfaces.
