Vararam
Old 04-20-2017, 03:05 PM   #1
RandomCamaroSS
Drives: Black 2011 Camaro 2SS
FAST Lsxr intake manifold need tune?
So I picked up a 102mm FAST lsxr intake manifold with 102mm ported throttle body... I was wondering if it requires a tune right away or could I drive with it right after install. I plan on getting the car dyno tuned in the near future.
Thanks in advance
RandomCamaroSS is offline   Reply With Quote
Old 04-20-2017, 04:39 PM   #2
eLeSthree
Drives: 2011 Camaro SS 6sp
Ive never owned one but i would say hell yes you need a tune.
Just curious, what else is done to the engine to need that intake?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 04-20-2017, 04:43 PM   #3
RandomCamaroSS
Longtube headers, ls9 cam, cai and 3.91 gears
Old 04-20-2017, 04:48 PM   #4
0331Marine
0331Marine's Avatar
Drives: 2012 SS/RS MN6
Would love to see before and after
0331Marine is offline   Reply With Quote
Old 04-20-2017, 08:12 PM   #5
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Dont "need" it to drive it. You can tune it later.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 04-21-2017, 04:42 PM   #6
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Worst case you might see some stalling, hanging idle, idle hunting, running rich, and slugglish low end without a tune.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 04-21-2017, 07:27 PM   #7
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
The ECU will just like a PTB have to relearn the AFR as the flow should increase slightly but I would say its ok to drive until your tuned unless it really sucks bad long beyond what you think is the learning curve. And you must have went with big money for the Nick Williams drive by wire, the whole deal is unless your built and larger cubes you may not get much from it.... Would be better on my engine as its been reported over the years the gains are negligible stock cubes mild build not worth the bucks. Now if your going to plumb all the bosses with nitrous or something it may be worth it to you..... Other than that you should have done the research... lots of old posts long ago on it, its dyno gains are even measured off a ls7 not a ls3....
christianchevell is offline   Reply With Quote
Old 04-22-2017, 09:59 PM   #8
eLeSthree
From what ive read, I dont think you stand to gain much power from the fast intake on that setup. Look into it, but i think its pretty expensive for 10hp. The stock ls3 intake is pretty good. good luck
1158whp 1017wtq.
630whp 658wtq
Old 04-23-2017, 12:10 AM   #9
rrrocketman
youtube.com/c/ChrisCamaro
Drives: 2013 Camaro SS w/ NPP and Hi Wing
Unless your tune was horrendous in the first place, you can easily drive without a new tune. The fuel trims will simply adjust themselves and the car won't run at peak performance until you do.
rrrocketman is offline   Reply With Quote
