Old 02-23-2017, 07:41 PM   #1
Drewcifer
Drives: 2014 Camaro SS
Long tubes with cats/Disappearing CEL?
Recently I had a set of Stainless Works long tube catted headers installed along with a drop in K&N filter element. I drove it the first day or 2 with the CEL on until I could get it tuned. Great power and sound. Yesterday I noticed the CEL was gone. Same today. Is this a temporary thing? Anybody else experience this? Thoughts.....?
Drewcifer is offline   Reply With Quote
Old 02-23-2017, 08:54 PM   #2
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Probably o2 sensor related. You should have the code read next time to be sure, but it's normal to get an o2 code intermittently after hi flow cat install. The tune should remove the cel if done properly.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 02-23-2017, 10:11 PM   #3
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
Mostly like o2 related as stated. Hi flows have a chance, albeit a smaller one than the catless route, to throw an o2 sensor code. The car will turn the CEL off after a few drive cycles if it doesn't see the problem again. It's only a matter of time before it returns. Best way to go about it is getting them tuned out. That way you can also maximize the most power out of them with the tune as well.
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 02-24-2017, 02:04 AM   #4
Drewcifer
Ya. I'm getting the tune in about a week. It'll be interesting to see if the CEL returns. I had a 10 SS that had 27k MI on it when I got it and I put OBX R long tube and hi flow cats on with a K&N filter and the CEL stayed on steadily. I'm surprised it turned off with this car. This is a 14 with only 6k miles on it. Better headers though for sure. Thanks for the input
Old 02-25-2017, 10:31 AM   #5
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
delayed response from o2s, remove o2s at rear needed in tune along with removing part of code showing the fronts delayed response due to their being farther away....
christianchevell is offline   Reply With Quote
Old 02-25-2017, 01:24 PM   #6
DokWatson
Dok
DokWatson's Avatar
Drives: 2015 Camaro 1LS M6
Both my car and truck don't care about not having cats, only threw codes once or twice then never came back. Don't know why, never cared! I'd imagine you'd be in even better shape having cats.
Hoonigan/Technician
Check out my channel.
https://www.youtube.com/user/AK49Watson
DokWatson is offline   Reply With Quote
Old 02-25-2017, 03:23 PM   #7
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
He has hi flows
Old 02-26-2017, 01:43 AM   #8
Drewcifer
Day 4 and no CEL
Ya guys. Day 4 and still the code has not returned. I'm still going to tune it but it sure is nice not having to look at it until i do
Old 02-26-2017, 05:36 PM   #9
Drewcifer
And it's back
This morning I drove my car on the freeway and the CEL came back on. Oh well. Soon to tune
Old 02-26-2017, 05:47 PM   #10
Test_Eng
Drives: 2013 1SS RS 1LE NPP ADM LSA CON
Black tape mod or get a tune. Very rare to see anyone install headers on these cars and not get a CEL. Had the same problem when I bought my car used from the dealer. Original owner installed kooks long headers and a K&N CAI. The light came on as soon as I pulled out of the dealer but never came on during the test drive.
To get the most out of the mod a Tune is required and more importantly in my case I need to pass emissions so it was a no brainer.
Test_Eng is offline   Reply With Quote
Old 02-26-2017, 08:19 PM   #11
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
In my opinion, getting the cel is a good sign that your cats are better flowing. If you never get the cel, then the airflow must be similar to stock.
Old 02-26-2017, 09:43 PM   #12
Drewcifer
Good points on both. A tune is definitely in the works. I've got a guy willing to do $400 unlimited tunes for as long as I have the car. Setting up for 1st week of March. The light was still on when I drove home. Guess I can live with it 1 more week.
Old 02-28-2017, 02:02 PM   #13
ARuiz9
Drives: 2015 Camaro SS 1LE
What's the black tape mod? And will your car pass emissions after/if the rear o2 are shut off?
ARuiz9 is offline   Reply With Quote
Old 02-28-2017, 02:13 PM   #14
Juiced1
Drives: 2012 2SS CAMARO 45th
Waiting a bit to get your tune won't hurt anything. But keep in mind you're leaving power on the table and generally running very rich before the tune.
Juiced1 is offline   Reply With Quote
