Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 06-16-2014, 07:39 PM   #1
ender2664
Drives: 2016 2SS
Car hesitating
My car is having some issues hesitating from time to time. When I was at high elevation, filled my tank at a random gas station and tried to accelerate quickly it got even worse.
Prior to that I was using shell 91. Any ideas of what could be causing it?
One time it threw a code, I believe it was P0300
ender2664 is offline   Reply With Quote
Old 06-16-2014, 07:46 PM   #2
MLAZ1990
MLAZ1990's Avatar
Drives: 2012 black camaro 2LS
I think P0300 is random misfire. I believe changing different brands/level of gas might make the car run funny without a fuse pull.
SLP Loud Mouth 1 Exhaust, K&N CAI, RS Headlights, NightOwl V2 halo kit, ZL1 Grille, Custom 2LS Emblems, Green Footwells, GM GFX splitter, Ace Alloy Convex All Matte Black Wheels(20x9 & 20x10.5) wrapped in Toyo Proxe STII(255/45/20 & 295/40/20)
MLAZ1990 is offline   Reply With Quote
Old 06-16-2014, 07:49 PM   #3
Muscle Car Lover
Muscle Car Lover's Avatar
Drives: 2014 2SS M6 "CHRISTINE"
Probably just the gas, but check your plug wires and plugs to be sure something is not going on in that area.
"But, House Mormont remembers. The North remembers! We know no King but the King of the North whose name is Stark. I don't care if he's a bastard. Ned Stark's blood runs through his veins. He's my king–from this day until his last day."
Mods: ARH headers and hi flow cats, VMAX ported throttle body, CAI air intake, Slowhawk Performance tuning
Muscle Car Lover is offline   Reply With Quote
Old 06-16-2014, 07:50 PM   #4
sean90
sean90's Avatar
Drives: 2014 2SS
at high elevation there is less air for it to suck in, and as a result it won't be as responsive or powerful.
sean90 is offline   Reply With Quote
Old 06-16-2014, 08:26 PM   #5
ender2664
Drives: 2016 2SS
Thank you
I'll be more careful of the gas i use
Old 06-16-2014, 08:52 PM   #6
EMB135Driver
Jedi Master
EMB135Driver's Avatar
Drives: Boeing 757/767+2010 IBM 2SS
Actually the atmosphere at high elevation is identical to that at sea level.....same amount of air is available for sucking, but the car can't suck in as much as sea level due to reduced air pressure.
EMB135Driver is offline   Reply With Quote
Old 06-16-2014, 10:54 PM   #7
Towlie
Towlie's Avatar
Drives: 2013 2SS/RS L99
I find this to be incorrect. If that were the case, people would not need oxygen bottles to climb Mount Everest. There is a definite reduction in the amount of oxygen to burn the higher in elevation you go. A car will pull the same amount of "air" at altitude, but the amount of oxygen available to burn is less. It's a 3-5% reduction In Power per 1000 feet of elevation.
Towlie is offline   Reply With Quote
Old 06-17-2014, 03:09 AM   #8
DandDC09
DandDC09's Avatar
Drives: '10 2LT/RS, '13 Malibu
There isn't any plug wires to check. They're coils sending your spark. It's gas most likely. I went to a ported throttle body and mine improved some.
And as everyone else has stated, elevation will play a roll in it too.
DandDC09 is offline   Reply With Quote
Old 06-17-2014, 07:57 AM   #9
jbrown13
jbrown13's Avatar
Drives: 2011 Camaro SS L99
You are correct when you talk in CFM of air. Air at elevation is less dense (weighs less per cubic foot), and although you might be pulling in the same CFM, you are pulling in less pounds of air, hence less pounds of Oxygen which makes up approx. 20.8% of the air we breathe. This is the same principle used by a blower, which densifies the air during compression, and a CFM of air weighs more at the higher pressure and you have more Oxygen to support combustion. Temperature also will affect air density. Cooler air equals denser air and vice versa.
jbrown13 is offline   Reply With Quote
Old 06-17-2014, 11:04 PM   #10
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
Yup, it's Boyle's law, and you just can't up and change that...
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
