dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Z/28 Forum - Z/28 Specific Topics
Old 11-17-2017, 07:25 PM   #1
JUSTIFIED
JUSTIFIED's Avatar
Drives: 2015 black Z/28
Installed Aeroforce Interceptor gauges....
Finally installed my Aeroforce gauges today (many thanks to Hammdo for recommending!). If you order them, be prepared for 4-6 weeks for pods to arrive. Their website didn't clarify that at time of purchase and gauges arrived within days so it was a bit frustrating waiting so long for pods.
However, well worth the wait!! Very cool and highly functional w/ many data display configuration options. Pics do not do them justice.
If doing again, I may have chosen green display instead of blue as it would match our guages a bit better.
Edit: Just noticed that the red arrow on both bezels in misaligned. When ordering you can order different bezels and you just slip them on. They rotate for easy adjustment.
JUSTIFIED is offline   Reply With Quote
Old 11-17-2017, 08:03 PM   #2
Zslash28
Jumanji
Zslash28's Avatar
Drives: '14 Z/28 - AGM - No A/C
Nice! Throttle %, that would be nice, and gear indicator wouldnt be too bad either.
Keeper of the 5th Gen Z/28 Registry.
Registry Facebook.
Follow: @5th_gen_z28_registry
I track wrecked Z/28s Total lost -41
Zslash28 is offline   Reply With Quote
Old 11-17-2017, 08:09 PM   #3
JUSTIFIED
JUSTIFIED's Avatar
Gear indicator is an option....
Old 11-17-2017, 08:26 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
Cyclic display and you get 16 parameters to watch!
Looks awesome!
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 11-17-2017, 08:44 PM   #5
hollywdv
hollywdv's Avatar
Drives: 2015 Camaro Z/28 - Silver
got one of these with a single pod. 2 pods looks awesome!
hollywdv is offline   Reply With Quote
Old 11-17-2017, 08:58 PM   #6
ZapperZ
ZapperZ's Avatar
Drives: 2018 ZL1 1LE 2022 GMC AT4 HD
I like it!
Does it plug into OBD2 ?
I hate the info display in the center of the dash located in a position were the steering wheel blocks your view
ZapperZ is offline   Reply With Quote
Old 11-17-2017, 09:04 PM   #7
JUSTIFIED
JUSTIFIED's Avatar
Originally Posted by ZapperZ View Post
I like it!
Yep, plugs into OBD2. Now that I have all this data I have to learn what it all means... fun!
Old 11-17-2017, 10:50 PM   #8
hammdo
hammdo's Avatar
Here is a YouTube of the Cyclic Mode in Action:
-Don
747 RWHP 794 RWTQ
Old 11-18-2017, 09:10 AM   #9
SquawkVFR
Drives: 2010 Camaro
Did you just get the gauge pod as well? It looks like they corrected the angle.
SquawkVFR is offline   Reply With Quote
Old 11-18-2017, 10:08 AM   #10
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Did you need to purchase the OBD splitter to run both gauges? I'm running a single, but need to run a double since I'm swapping in an LSA SC. The AFR the gauge is reading is just commanded, not read in the exhaust, correct?
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 11-18-2017, 10:57 AM   #11
ZapperZ
ZapperZ's Avatar
Wonder if OBD2 can be split to also run telemetry with this?
Old 11-18-2017, 11:10 AM   #12
I've heard that POD pops out at the mount sometimes. Interested to see how solid it is in that respect.
If you buy the gauges in a pair they come with the splitter, otherwise yes you would need that when purchasing the second one.
I had these on my 5th Gen and they were hard to read in the daylight.
Old 11-18-2017, 11:54 AM   #13
hammdo
hammdo's Avatar
My red work well in the sunlight, even during road racing. My pod has not popped out, don’t know about the newer ones..
mlee is right, already split!
I have the splitter, not 100% working, seems some pins not set...
-Don
747 RWHP 794 RWTQ
Old 11-18-2017, 12:08 PM   #14
-Don
Good to know. I had blue
My plugs were very touchy and it was very easy for them to unplug.
Great setup and I do like the location of the Pod using the vent. Just wanted to make sure it stays in before I get one.
