Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 03-11-2016, 09:03 PM   #1
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Sub, amp, and Box combo(?)
Alright, I need you sound guru's help. I am looking to add some thump to my BA system. I am not looking for window or bowel shattering bass/boom but something I can feel/hear well enough with the rest of the music. I am planning on upgrading my speakers and doing a mylink conversion in the near future. I want to upgrade the stock BA amp with a Alpine PDX-V9 and run two 10in subwoofers. I am looking at sub-thumps two 10in enclosure and either of the following subs.
http://www.crutchfield.com/p_575R2D4...e-R2D4-10.html
http://www.crutchfield.com/p_13610WX...v2.html?tp=111
I am looking for subs that run 250watt RMS because the Alpine amp funs 500RMS either 2ohm or 4ohm. I know I can wire the subs up to run at 4ohm and run them from a mono channel amp. My biggest concern is about the enclosure and subs. Is it going to be too big, meaning too much free space inside for these subwoofers to operate properly? I listen to rock, country, metal, and little hip hop, rap, trance, or dance.
Thank you for the help and any recommendations.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 03-12-2016, 08:18 AM   #2
dentnshell
dentnshell's Avatar
Drives: Black 2014 2SS
I have been chasing down a similar problem... The volume that JL Recommends is not the same that most calculators recommend...
Sealed Box
Vas = 47.01 lts
fs = 29.38 Hz
Qts = 0.45
Qtc = 0.707
Vb = 1.13 ft3
f3 = 46.17 Hz
fb = 46.16 Hz
I too am interested in feedback.
2014 L99 2SS. 595HP/571ft-lbs
Mods: LSA Conversion 2.5" Upper Pulley, 65# injectors, GPI SS1 Cam, SP Long Tubes, ADM Race Scoop & CAI, NPP exhaust (DIY control), BMR 1" lowering springs, ZL1 Rear Differential / Axles, CF Side Strip / Hood Spear, Tint - Windows / Tails / Sidemarkers, Splash Guards, ADM Boost Gauge, ABL Dashkit, '68 Script Badges, ACS T4 Splitter, ZL1 Rockers from Gary's, Z28 Spoiler, Carbon Fiber Hood Vent, Summer - MRR FS01 Satin Black (10" Front 11" Rear) Winter, pictured-Drag DR 64's Satin Black (9" Front-10" Rear.)
dentnshell is offline   Reply With Quote
Old 03-12-2016, 11:33 AM   #3
cabbe
Drives: 2014 2ss 1le
Why not get a single sub? I run the pdx v9 to a single jl audio w7 10". Its got fantastic bass and uses very little space.
cabbe is offline   Reply With Quote
Old 03-13-2016, 03:44 PM   #4
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
A single sub with 500 watts will be more than enough for any type of music. I use a 12" Boston G3 in a 1 cuft stuffed box with 600 watts @ 4 ohms, and it is removable if I need the trunk for something else.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
Old 03-13-2016, 08:45 PM   #5
coryrulez9
Drives: 2014 Camaro 2LS Blue Ray
I installed a Rockford P300-10 sub in my car and am extremely satisfied. There are some other threads on here from others who have as well. Its the best bang for buck imo and is easy to install with some T taps to the rear speakers.
http://www.amazon.com/Rockford-Fosga...s=rockford+p10
coryrulez9 is offline   Reply With Quote
