04-13-2015, 08:00 PM | #1 |
Drives: 2015 Blue Velvet 2ssRs1Le Join Date: Mar 2015
Front license plate?
Unsure about putting front license plate.
04-13-2015, 08:06 PM | #2 |
Drives: 2013 ZL1 Triple Black Vert M6 #5591 Join Date: May 2013
I won't. Just give me the ticket. If the cops in my area need to pull me over for a license plate infraction. They most certainly will get An earful and my PBA Card. Just sayin
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice.. |
04-13-2015, 08:07 PM | #3 |
Drives: 2014 SS/RS CRT Join Date: Jan 2014
The car looks great as is. Don't do it. Looks awful and totally destroys the aggressive look of the front end.
I live in Jersey where it is required and told the dealer that if he put on the plate bracket the deal was off. Yeah I know. I run the risk of being ticketed. |
04-13-2015, 08:13 PM | #4 |
Drives: 2013 ZL1 Victory Red Vert Join Date: Jul 2014
I wouldn't put it on unless you kept getting hassled by the cops. Then I'd get the the one that hides under your front end.
04-13-2015, 08:50 PM | #5 |
Drives: 2017 RS Redline Edition Join Date: Dec 2014
I say if it's the law...do it. It will save you a fine or more.
04-13-2015, 08:53 PM | #6 |
Drives: 2017 2SS, 2000 Trans Am Firehawk Join Date: Jun 2014
I broke down and did after getting pulled over. I don't need the hassle.
04-13-2015, 08:54 PM | #7 |
Ben Rakers
i dont have one and its required here in Illinois. Iv'e never had a problem.
2011 Camaro 2SS/RS K&N Blackhawk Cold air intake, Hawk Performance Ceramic pads, BAER drilled and slotted rotors, Side louver black faded inserts, Hurst Short Throw Shifter, BMR Trailing Arms, Elite Engineering Catch Can, MSD Spark Plug Wires, Texas Speed 1 7/8in Headers and cat back, High Flow Cats, 3 inch X-Pipe, Speed Dawg shift knob, Tuned by Nickey. And oh, its My first car.
https://www.youtube.com/channel/UC_L...5jF6EQEoKDNQ2g |
04-13-2015, 08:55 PM | #8 |
Drives: 2013 SS 1LE Join Date: Jul 2014
If you are a social drinker, definitely get one. Imagine having a couple drinks and being barely over the limit, then getting a DUI for something as trivial as no front plate.
Get a plate holder that doesn't require drilling holes. Then you could just remove the plate for pictures or if riding dirty or whatever. |
04-13-2015, 08:56 PM | #9 |
Drives: '14 ZL1 RRM M6 Join Date: Aug 2014
Law says I'm not supposed to drive over 65 mph....not paying much attention to that one either!
ADM ZL 750 PACKAGE...697RWHP/680RWTQ
04-13-2015, 08:56 PM | #10 |
Drives: 2015 camaro ss Join Date: Mar 2015
I have mine attached via some command strips. I actually had my lower grill replaced because it had a lp bracket mounted
04-13-2015, 09:00 PM | #11 |
Drives: 2014 Z/28 #398 Join Date: Dec 2014
04-13-2015, 09:01 PM | #12 |
04-13-2015, 09:04 PM | #13 |
04-13-2015, 09:07 PM | #14 |
Get a jacfab. He supports this forum and it mounts form underneath.
