12-18-2014, 07:36 PM | #1 |
******** enclosure correct size?
I just left an audio shop because I feel like My sub is not as clear and tight as it should be so I was going to let a pro tune my bass amp. He told me it was tuned well but that my problem is that I needed more airspace for my sub and that the ******** box was too small. By no means is this a bash on ******** I've had this box for two years and love how small it is and its amazing quality , but in short... Would going to a bigger box solve my sound quality issue or is the installer wrong?.
Some info: Amp-pr600x1 Memphis (600 watt rms) Sub-12' t0 Rockford fosgate (700 watt rms)
*Performance:
mrt v2.0 exhaust/CAI Intake *Cosmetic: Zl1 factory Reproduction wheels Bmr 1.2/1.4 springs/Oracle plasma drl lights, footwell ambient lighting, 45th Gobo lights *Audio: Memphis pr600 amp/Fosgate 12" t0 sub/******** stealth box |
12-18-2014, 09:35 PM | #2 | |
Drives: 2014 Camaro 2LS Blue Ray Join Date: Jan 2010
If you have the regular stealth box, its 1.2 cu inches. .05 is close enough imo. |
12-19-2014, 01:26 PM | #3 |
Drives: 2014 2LT/RS Ashen Gray Metallic Join Date: Nov 2011
You can also "trick" the woofer to think it is in a bigger enclosure by filling the box with polyfill material. This should make the sub play lower and tighten up the bass response.
12-19-2014, 02:43 PM | #4 |
Thanks for the responses I appreciate the help. When you say will make the bass play "lower" what exactly do you mean. I feel like my system plays the low notes (such as rap or hip hop) very well but when listening to country or rock most of the time my bass is nonexistent except for during certain parts of the song. The best way I can think to describe it is the bass feels disconnected from the rest of the system. I know a 10 would be better for the higher bass notes but I feel like I should at least be getting something from the 12
*Performance:
