Old 03-14-2018, 09:06 PM   #1
SkipNWis
SkipNWis's Avatar
Drives: 2016/SS Has had 4 Gen 5's
Help with Burnout's?
I can not get my car or any V8 Camaro I have had to do a Burnout? I have had 3 different V8's All I get is either stick and go or burned clutch smell ?????? what the hell am I doing wrong??
SnoWhite
SkipNWis is offline   Reply With Quote
Old 03-15-2018, 08:51 AM   #2
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
Turn off the traction control and stability control. Then second gear, 4K and dump the clutch. It’ll smoke any tire you have on the car.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
Old 03-15-2018, 08:59 AM   #3
SSummit
Drives: 2013 Camaro ZL1
And grab the brake with your left foot.
SSummit is offline   Reply With Quote
Old 03-15-2018, 09:39 AM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Press and hold the traction control for 10 seconds to turn off all traction aid devices.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 03-15-2018, 10:02 AM   #5
Cdflyer
Cdflyer's Avatar
Ehh, only if you want to stand there and create a cloud. It’ll make plenty of smoke on street tires without the brakes.
I use the line lock and it gets the tires nice and toasty.
Old 03-20-2018, 11:47 AM   #6
trueraiderfan17
Drives: 2018 ZL1 A-10
2nd gear huh? I have not tried that. what about if you're on drag radials?
trueraiderfan17 is offline   Reply With Quote
Old 03-20-2018, 12:11 PM   #7
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
So as far as a brake stand burnout I’m not able to do so what so ever s, I can launch the car in first or 2nd with traction control / all nannies off with no problem but a stand still is never going to happen. I’m going with the route as far as purchasing the line lock for our cars for the drag strip.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 03-20-2018, 06:05 PM   #8
Cdflyer
Cdflyer's Avatar
Any tire will not keep from spinning. I’ve done 100ft long burnout by sidestepping the clutch in second gear. It creates tons of smoke. Believe it or not, but the slicks made more smoke then the street tires did.
