TireRack
Old 01-17-2018, 12:31 AM   #57
bayarea408
bayarea408's Avatar
Drives: T
that polish on polish bead lock looks really good!
bayarea408 is offline   Reply With Quote
Old 01-17-2018, 07:18 AM   #58
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Beautiful ride.... but I predict lots of melted stuff. As pretty as ceramic coating only kits are, on these cars the heat is intense with top mounted turbos... I would add heat wrap to save everything under the hood lol.
RealQuick is offline   Reply With Quote
Old 01-17-2018, 12:03 PM   #59
bayarea408
bayarea408's Avatar
Drives: T
If you go heat wrap check out DEI stuff its less "itchy" LOL
Old 01-18-2018, 09:14 AM   #60
SannerRacing
SannerRacing's Avatar
Drives: 2010 1SS RS IOM
I know but I hate that stuff lol. So will see how it goes, I have DEI turbo blankets to install after I get it back from getting it tuned.
Forged LS3 416ci, Maggie TVS2300 @ 13lbs boost, McCleod twin disc clutch, GForce 1320 nine-inch 389 gear ratio, Hurst line-lock, 750 whp 700 wtq
SannerRacing is offline   Reply With Quote
Old 01-18-2018, 12:21 PM   #61
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
When is dyno day? For some reason I was thinking it was Jan 5th but obviously I was mistaken. We all agree it is pretty, but where is the beef? Just kidding . . . it should be a beast!
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 01-18-2018, 02:12 PM   #62
jeff657756
Drives: 2014 SS 1LE
Looks like he relocated alot of the stuff us normal guys would have to worry about. Coil relocate, no plug wires to melt. No fuse box wiring, etc to worry about. I would take that setup in a heartbeat.
jeff657756 is offline   Reply With Quote
Old 01-19-2018, 09:33 AM   #63
SannerRacing
Lol Your where right,the 5th was going to be the day but issues and life got in the way. I hope next week is the week! It's at CMS now and I'm as anxious about numbers as anybody else. Lol Drove it down there but can only use about 1/4 throttle it's pure torture
Old 01-23-2018, 04:13 AM   #64
2010SSRSM6
2010SSRSM6's Avatar
Drives: My wife crazy with my C5 usage.
Don’t pull a Troy on the Dyno......
UNDER CONSTRUCTION......again......
2010SSRSM6 is offline   Reply With Quote
Old 01-23-2018, 11:05 AM   #65
SannerRacing
Rick you know that was a stock rod trying to hold on to 1200rwhp lol it would be a real shame to have to build another motor!
Old 01-23-2018, 02:11 PM   #66
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
Nice! What HP gains do you expect? I have a Maggie SC and it's rated at about +125. I'm sure yours has a much higher gain.
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 01-23-2018, 10:49 PM   #67
SannerRacing
When I had the Maggie on there we maxed out at 750rwhp on a mustang dyno and we just couldn't make any more boost with low enough IATs without more mods and that's when I pulled the plug. Plus belt issue and a few other things. With the twins I'm hoping for a more boost controllable power and to be in the neighborhood of a 1000rwhp. Should know sometime next week. Thanks
Old 01-25-2018, 11:40 AM   #68
2010SSRSM6
2010SSRSM6's Avatar
Old 02-15-2018, 10:13 AM   #69
SannerRacing
Lesson learned
Well as in anything when you do it yourself and it's not your day job you take a risk. So that being said I plumed the oil regulator going to the turbos wrong and killed both turbos. So 1600. Later I got them back and am in the process of putting them back on and going to the dyno Tuesday morning probably only going to have time to run it on springs only and dial in the boost controller later. Hopefully I'll post some numbers Tuesday.
Old 02-20-2018, 04:58 AM   #70
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
WHERE'S THE BEEF!
Good luck today.
Don't push it. Been watching this for a while. Patients is key.
I really enjoy seeing people get to enjoy their own work.
Really great project.
UNRIVALED SS is offline   Reply With Quote
