Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 08-02-2013, 09:46 AM   #1
Dumbman12
Drives: LT
Put wrong type of fuel, CEL is on
put the wrong type of fuel in my car now the check engine light is on what must i do?!
This is not a Troll post !!
and the fuel i put on my LT was E85
Dumbman12 is offline   Reply With Quote
Old 08-02-2013, 09:48 AM   #2
Toms2010
Drives: 2010 2LT
What fuel did you put in?
2010 2LT CGM Auto
Vararam CAI - Modern Muscle Ported Throttle Body - Vmax Black Iceolator - Custom Exhaust - Magnaflow Res X 11386 - 2.5" Pipe from X on Back - Magnaflow Round Mufflers 10416 - Lime Green Hood Spears - Lime Green Gill Stripes - SJM AutoProd Sequential Turn Signals - SJM AutoProd Always On DRL Fog Lights
Toms2010 is offline   Reply With Quote
Old 08-02-2013, 09:49 AM   #3
Swacer
Drives: 2018 GT350
Did you put a lower octane in? I thought the V6 could use 87 without issue?
I would check the code, make sure its just a knocking code due to low octane, then perhaps consider picking up an octane booster to raise the octane level?
Off to the Dark Side
Swacer is offline   Reply With Quote
Old 08-02-2013, 09:51 AM   #4
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
The only fuel that would trigger the light is E85 or maybe E15. It won't run on that well at all. You're going to need to have that fuel removed from your tank, refill with correct fuel, then clear the codes.
Bye bye, Bumblebee!
strych9 is offline   Reply With Quote
Old 08-02-2013, 09:51 AM   #5
jewel25
Mother of PWA Babies
jewel25's Avatar
Drives: 2011 RJT 2LT/RS
I been running 87 for over 2 years. No issues here.
I am wonder what kind of gas the OP put in the tank to cause issues.
Diesel???
jewel25 is offline   Reply With Quote
Old 08-02-2013, 09:52 AM   #6
jkchambless
Austin LT
jkchambless's Avatar
Drives: 1LT - Airaid,JBA Axleback,VMax PTB
The only "wrong" fuel for an LT is E85 or diesel......
jkchambless is offline   Reply With Quote
Old 08-02-2013, 09:52 AM   #7
87GNX
87GNX's Avatar
Drives: Alot
Diesel?
87GNX is offline   Reply With Quote
Old 08-02-2013, 09:53 AM   #8
Swacer
Drives: 2018 GT350
If its diesel...damn...gonna be an expensive fix.
Old 08-02-2013, 09:53 AM   #9
jewel25
jewel25's Avatar
OP, We need more information if we are going to help you.
Old 08-02-2013, 10:02 AM   #10
Swacer
Drives: 2018 GT350
Originally Posted by Jordan23 View Post
The diesel nozzle is bigger isnt?
The smell and the foaming should have given that one away.
Old 08-02-2013, 10:03 AM   #11
JR 1
JR 1's Avatar
Drives: 2014 2SS/RS Convertible
Maybe OP just didn't get the gas cap tight. That can set off the check engine light.
JR 1 is offline   Reply With Quote
Old 08-02-2013, 10:03 AM   #12
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Yeah, you cant actually fit a diesel nozzle in a gas receiver, it would spray everywhere. I'd say he accidentally put E85 or something in her. Been running 87 for 3 years.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 08-02-2013, 10:04 AM   #13
JR 1
JR 1's Avatar
With no info from the OP we could speculate all day...
And probably will!
Old 08-02-2013, 10:08 AM   #14
jewel25
jewel25's Avatar
Good to know.
