01-16-2013, 02:28 PM | #1 |
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6 Join Date: Dec 2011
Looking through new Long Blocks
I'm considering just buying an all new engine vs forging my current L99. Would anyone care to tell me what all is missing on a long block?
Also why is it that if you look at lingenfelter vs TSP there is a huge price difference. Is that because lingenfelter is listing their installed price? Oh, and also I have seen alot of people get LSX blocks but not anyone who has the LS7 blocks. Why is that? |
01-16-2013, 02:32 PM | #2 |
Drives: 2010 SS , 1970 Z-28, 2002 Avalanche Join Date: Aug 2009
Most of the time a long block is everything except the intake, water pump, oil pan and pullies. I see your in Ohio so you might want to check with Livernois Motorsports, they have MANY options to suit your needs. Their site is Livernoismotorsports.com. Good luck.
IF IT'S WORTH HAVING, IT'S WORTH WAITING FOR!!!! (AND IT WAS)
434RWHP/403RWTQ Livernois Motorsports 2C Cam kit Kooks 1 7/8 LT Headers/Hi-Flo Cats/Corsa Exhaust Roto-Fab CAI / Port Intake Precission 2400/2800 Converter/3.73 AAM gears Livernois Motorsports Tune Best time: 11.97 @ 117 MPH |
01-16-2013, 03:26 PM | #3 |
Drives: 11 Seconds or Faster Join Date: May 2012
LSX is one of the strongest motors out there, but cost wise you will spend way more for the long block, and if you do an LS7 it wouldn't be much stronger than your L99.
01-16-2013, 05:42 PM | #4 |
V8 lounge member #5
I'm having trouble finding what cams they put in them. Do they put in stock cams unless requesting a different one?
01-16-2013, 06:14 PM | #5 | |
Drives: 1987 Buick Regal Turbo-T Join Date: Sep 2009
The LS7 block is pretty much the weakest engine block when it comes to these LS engines. Typically, if someone is wanting 427+ CID we recommend a resleeved LS3 block, an LSX block, or, at the top tier, and RHS block. As far as cams, for a longblock, we include our custom camshaft in the build pricing, but we do have many options for custom tailor it to your specific needs. Feel free to give us a call if you have any other questions. |
01-16-2013, 06:23 PM | #6 |
Drives: 68,69,72&10 Camaro's 12 CTS-V Join Date: Sep 2009
I would talk to Andy from Livernois.
Vinnie
01-16-2013, 06:26 PM | #7 | |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
01-16-2013, 06:33 PM | #8 |
I have looked at their flyers, but have not seen one in person. We have never had any LSX block issues, but I have seen where some people have. I guess it just depends on how hard you want to push it. The only way I would consider it superior would be in CGI instead of gray iron.
01-16-2013, 06:42 PM | #9 |
Drives: '69 SS Convertible Join Date: May 2009
Mast Motorsports is a big player in the LS world as well.
Call around and research a few to determine what's best for you.
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal |
01-16-2013, 06:44 PM | #10 |
do you have a forced induction setup or are you looking for big cubes NA horespower?
01-16-2013, 07:01 PM | #11 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
If you are looking to do a NA stroker that runs on pump gas, you could just keep running an aluminum stock block. I'd only go LSX, RHS, Dart for a power adder or extreme compression NA setup.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
01-16-2013, 07:02 PM | #12 |
Exactly where I was going with it, good man
01-16-2013, 07:03 PM | #13 |
Chevrolet Performance
Drives: Camaro Chroma Join Date: Jul 2010
If you are looking for big horsepower and factory reliability check out the new LSX376-B15 from Chevrolet Performance. Capable of 15 pounds of boost and up to 1,000 HP!
http://media.gm.com/media/us/en/gm/n...lsx-block.html |
01-16-2013, 10:09 PM | #14 |
V8 lounge member #5
Well I have most other car parts for my build except the engine and tranny. I already purchased my vortech ysi. I'm thinking of running about 12 lbs and prob meth for safety. I just want something that won't break while running 93octane.
Originally I was going to pay for someone to put in forged pistons, rods, arp studs, ls3 convesion and cam. But if that's gunna cost 5k and a long block is 9k ish. Why not go for keeps?? I can put an engine in a car but I don't want to deal with the headache of working on engine internals. Last edited by K32 Camaro; 01-17-2013 at 05:19 AM. |
