Old 03-21-2023, 07:19 AM   #1
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
BMR Adjustable End Links
These are intended with a stock ride height to be matched to the length of the OE end links, but shorter, or longer, does that not affect the bar rate? I understand an adjustable bar and how that works but first experience with adjustable end links. I think that these adjustable for lowered ride height and not making any contact with other bits under the car, right?
Old 03-21-2023, 07:37 AM   #2
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
Within reason, changing the end link lengths won't change the rate significantly. By changing the angle of the bar's arms, you can alter the rate a bit and also the "curve" of rate gain/loss as the suspension moves and the arms swing through their arcs. But it won't be a big change. The big reason for adjustable end links is to adjust one end link's length relative to another in order to add or eliminate preload in the suspension/wedge. In a circle track car, this could be a useful tuning tool for handling balance, but on a car that has to turn both directions you generally just want to zero it out. However, it could be used to adjust corner weights if you don't have adjustable spring perches.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 03-26-2023, 08:27 AM   #3
WhiteMale
They went in easy-peasy, the bar was a real PITA though.
Old 03-26-2023, 07:14 PM   #4
clyde
clyde's Avatar
Drives: broken
I've often appreciated them for providing the ability to actually use all the holes on adjustable bars when stock endlinks aren't long or short enough.
clyde
Team WTF?!
what are you gonna do? :dunno:
clyde is offline   Reply With Quote
