dave@hennessey
Old 10-01-2020, 05:34 PM   #1
supersnake05
supersnake05's Avatar
Drives: 2015 Camaro SS 1LE, 2014 Chevy SS
Vented oil cap on 1LE?
Just a random question. I just bought a 2015 1LE Camaro and it has a vented 3 piece oil cap with a plastic hose coming off the intake tube. My wife has a 14' SS that doesn't have it. The car was from New York with emissions from that area on the window sticker. Is that an emissions deal from those areas?
supersnake05 is offline   Reply With Quote
Old 10-01-2020, 06:12 PM   #2
Scooter18155
Scooter18155's Avatar
Drives: 2010 ss/rs 6 speed manual
Not an emissions thing. It’ll like an oil separator. It is good to have came on 1le cars. Non 1le didn’t come with it
2010 camaro ss/rs, standard 6 speed, ls3 motor, bmr subframe connectors, jba 3” competition Exhaust, stainless works 1 7/8" headers, adm cold air intake, hurst short throw shifter, bo white ported tb, mishimoto aluminum radiator, mishimoto oil cooler.
Scooter18155 is offline   Reply With Quote
Old 10-01-2020, 06:49 PM   #3
supersnake05
Awesome, thank you.
Old 10-01-2020, 07:40 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Yep, it's what Scooter said. Its the 1LE clean Side Separator. I bought an OEM one from someone on here last year for my SS to work with my catch can/PCV system. Even if you decide to remove it one day I would still hang onto it. 20+ years from now those things will likely be hard to come by.
InFiD3ViL is offline   Reply With Quote
Old 10-01-2020, 07:45 PM   #5
Scooter18155
Yes hang onto that if you don’t like it. Personally I bought an elite engineering one for my car. It’s not a bad thing to have
Old 10-02-2020, 12:06 AM   #6
Vegas Bound
Drives: 2013 Sparkly Red One
I have an extra one if anybody wants to buy it.
Vegas Bound is offline   Reply With Quote
Old 10-02-2020, 06:33 AM   #7
byrds8
byrds8's Avatar
Drives: 2013 Camaro 2SS, L99
Are these needed on a L99?
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
byrds8 is offline   Reply With Quote
Old 10-02-2020, 08:54 AM   #8
Scooter18155
I don’t know if the term needed is accurate for any motor. They separate oil from the clean side of your system and put it back into your oil system. Which is why it replaces your oil fill cap. I would say it’s a matter of opinion if it’s needed but your motor l99 or ls3 will function just fine without it. Myself I have one on my motor as it can’t hurt to keep your PCv system cleaner. There is thread about this you can find in searches. But if memory serves me correct the clean side separator we are discussing here has minimal effect except in wide open throttle situations. An actual catch can has great effect on the system and would suggest everyone install one.
Old 10-02-2020, 08:57 AM   #9
byrds8
byrds8's Avatar
Catch can has been installed since the day I purchased her. Granted I am the second owner but she only had 50K on her when I got her. Pulled off the hose running to the intake tube and nothing there. Cotton swabbed the inside of the hose also and zip. Guess it would be safe to say I wouldn't need to put one of these on then correct?
Old 10-03-2020, 11:05 AM   #10
mikeman
Drives: 2015 Camaro
Not really. They're needed on D.I. engines though since the fuel never reaches the back of the intake valves to help keep them clean.
mikeman is offline   Reply With Quote
Old 10-04-2020, 01:53 PM   #11
InFiD3ViL
InFiD3ViL's Avatar
I have never noticed any difference after I installed the 1LE separator on my car, nor would I really even know what to look for. I just wanted to 'complete' the PCV system and for it to work with my dirty side catch can. Honestly, I just like the idea that it's on there and think it looks cool lol. I think I paid $50 bucks for it, so no big deal either way. On the other hand my catch can does a great job collecting 2-3 ounces of stink filled nastiness between each oil change.
Old 10-05-2020, 12:10 PM   #12
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
Only if you road course track day it.
The 1LE separator is different from a catch can. The 1LE piece is intended for road course... long left hand sweepers at high RPM. Under those conditions you can get a lot of oil up in the valve covers and in a left hand sweeper g-forces it can put that liquid oil into the pcv... then up into the intake. That 1LE separator puts that pcv hose up much higher away from liquid oil in the valve cover in those road course track conditions.
A catch can is for - all driving conditions. Helps keep oil out of the intake. Every car in theory can benefit from one of those. It's closed loop, changes no paths of the pcv system, just puts in a nice separator tank to keep the oil droplets from going into the intake. A good thing for both port or direct injection.
Just my opinion.... catch can - great for any performance car..... clean side oil separator like the 1LE piece - also add that on road course days.
Russell James is offline   Reply With Quote
Old 10-05-2020, 03:13 PM   #13
Scooter18155
Yeah I never noticed any difference myself either. And like you kinda wanted to complete the system. Figured it can’t harm anything having it from what I understand when I did my research. So I say better safe then sorry type situation. What russel James said is basically what I’ve previously read it’s most useful for. But if having it on doesn’t hurt anything I don’t see the point of putting it on and taking it off for track days. If leaving it on during non track days does in fact hurt something I have not been informed.
