Old 02-17-2020, 09:09 PM   #15
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
according to GM Performance Motor https://www.gmperformancemotor.com/P..._Code=84341929 they are the only ones who have these right now. Said he bought all they had. He believes GM is only selling them 10 at a time.
Old 02-23-2020, 04:21 PM   #16
L78toLT1
L78toLT1's Avatar
Even though i have the BMR Delrin kit on the shelf, i went ahead and ordered the gm kit. Promised my 1LE buddy a sweetheart deal on the BMR kit, but I ain't letting it go until I have the gm kit in hand!
Baby Blue
Old 02-23-2020, 06:51 PM   #17
JCunningham
Drives: 2017 2SS M6
i got mine a few days ago.
Old 02-24-2020, 11:44 AM   #18
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
still want to get this but the labor $$ is crazy i heard lol
Old 02-26-2020, 07:11 PM   #19
L78toLT1
L78toLT1's Avatar
Originally Posted by JCunningham View Post
yep just got my shipping notification too
Mine arrived today! JCunningham, you need to get the installation technique figured out! You have time though, I just got my car aligned so I'm going to hold until the next time I change tires. I'm doing my bushings and Hurst shifter in the same session. It's such a PITA getting these cars jacked that I try do do several tasks at once. Come to think of it, I'll probably change the fluid in my diff while I'm at it.
Baby Blue
Old 02-26-2020, 08:40 PM   #20
Scargoes
Scargoes's Avatar
Drives: 2018 Hyper Blue 2SS 1LE
I just saw this update, I ordered. Lets hope they still have one to send to me.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 02-27-2020, 07:04 PM   #21
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
Originally Posted by TRZ06 View Post
I am not sure that is a bad thing actually (with the exception of initial cost).
Having gone thru the process, it's a pretty intensive process, which usually requires heating up the rear cradle (potentially weakening the metal chemistry)
My performance shop opted for the more labor intensive route of sawing the rubber bushings out, rather than heating up the cradle. I was totally ok with that.
As a secondary reason, GM probably also wanted to make the price of entry steeper to protect the handling benefits of the ZL1 1LE. While the DSSV's are more track focused, the biggest upgrade to the stability and handling between the ZL1 1LE and the ZL1/SS 1LE are those solid rear cradle bushings.
I did a write up on changing them with the subframe still in the car. These dont need to be heated up into a fireball like old nissans. Its a min or 2 to melt the 3 drops of glue the put on and it pops right out
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
Joey Soul is offline   Reply With Quote
Old 04-13-2020, 08:56 AM   #22
6spdhyperblue
Drives: 6th gen
Is there any increase of stiffness or sharpness when hitting bumps or potholes? Even just a little I’d like to know. I like the very plush ride on my SS and don’t want to give any of that up.
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
Old 04-13-2020, 12:28 PM   #23
JCunningham
Drives: 2017 2SS M6
none that i noticed but i have my mod in signature.
Old 04-13-2020, 02:03 PM   #24
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
They do not alter vertical shock movements. The eliminates the lateral flexes of the rear-end.
There is no ride quality penalty whatsoever.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 01-16-2021, 03:11 AM   #25
Dabjbr
Drives: 2020 SS 1LE
actually its pretty easy with a 2 jaw puller impact and socket you can just push them out.
Resurrection....
Is there enough space to use the puller while the cradle is still attached?
Dabjbr is offline   Reply With Quote
Old 02-20-2021, 02:40 AM   #26
JCunningham
Drives: 2017 2SS M6
no. you have to drop the cradle so you can push the bushings out from the top.
Old 02-20-2021, 02:45 AM   #27
JCunningham
Drives: 2017 2SS M6
when installing the aluminum bushings. You have to install the top bushing 1st or it will not go in all the way and that will make your cradle crooked.
Old 02-20-2021, 08:58 AM   #28
20Bluezl1
So I just finished my installation of the GMPP bushing last week and I just realized I screwed up not sure if it makes a difference but you don't press the top bushing first.
The instructions say that the front bushing need the top press first but the rear the lower has to be pressed first.
I did all 4 lowers first hopefully it's don't make a difference. 😟
