dave@hennessey
Old 10-31-2013, 09:36 AM   #1
Go big or Go home
Go big or Go home's Avatar
Drives: 2010 Camaro 2LT RS
Arrow First Camaro with 6-piston SRT8 Jeep Brembo calipers
First Camaro with 6-piston SRT8 Jeep Grand Cherokee Brembo calipers.
My motto has always been "go big or go home" so the 4-piston Brembo and 14" rotor was no longer big enough. As soon as I saw the massive size of the SRT8 Brembo and 15" rotor I knew that's what my car needed.
To get an idea of the size of the SRT8 caliper, it measures approx 18" along the curved side compared to the ZL1 6-piston caliper which measures approx 16". SRT8 face is 4" wide vs ZL1 face is 3.5" wide.
The SRT8 Brembo is obviously not made for the Camaro so custom fabrication was needed to install them, but since my father is a custom fabricator that was not a problem.
Wanted to share some photos of the build...
6-Piston SRT8 Brembo vs 4-Piston Camaro Brembo
6-Piston brake pad vs 4-Piston brake pad
Pins and retainer from 6-piston vs pins and retainer from 4-piston
Drilling the correct bolt pattern for the 15" rotors...
Fabricating the custom bracket for the calipers...
Fitting the custom bracket...
More pictures of the completed install coming soon...
Go big or Go home is offline   Reply With Quote
Old 10-31-2013, 10:04 AM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
SWEET!!!
Apex Motorsports is offline   Reply With Quote
Old 10-31-2013, 10:06 AM   #3
toehead93
Drives: 2014 2SS/1LE
Looks nice, those are some massive brakes. Nice work.
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 10-31-2013, 10:08 AM   #4
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
That is bad ass right there!
tramtwo is offline   Reply With Quote
Old 10-31-2013, 10:32 AM   #5
Austin45
The Logistician
Austin45's Avatar
Drives: 2012 LFX 45th Anniversary
I do believe the Jeep has the largest production brembos
Austin45 is offline   Reply With Quote
Old 10-31-2013, 10:48 AM   #6
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
My question is how much more do they weigh over either the stock brembos or the ZL1 brembos, as the 15" rotor has got to add an extra lb or so to the weight.
So Cal Camaro is offline   Reply With Quote
Old 10-31-2013, 10:56 AM   #7
Dyk-NO
Trust me I'm a Scientist.
Drives: My wifey ;P
That's nice, want to see how it turns out.
"From ZERO to a Tire-Burning HERO!"
Mods: RotoFab CAI, SW Headers, HiFlo Cats, Borla Atak Catback, Nightfury Cam, Ported Heads,Intake,TB, melling pump, Morosso Oil Separator.
Dyk-NO is offline   Reply With Quote
Old 10-31-2013, 11:27 AM   #8
camaro500
camaro500's Avatar
Drives: 2017 Jaguar F Type R Tuned 498awhp
really impressive work. congrats. Are those vossen wheels? It must look amazing with the brake wheel combo
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller
camaro500 is offline   Reply With Quote
Old 10-31-2013, 11:54 AM   #9
ClawSS
High-tech Redneck
ClawSS's Avatar
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8
I see the re-drill offsets on the rotors. What is your opinion on the possible "wiggle" or integrity issues around the studs considering the egg-shaped holes?
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning.
ClawSS is offline   Reply With Quote
Old 10-31-2013, 11:57 AM   #10
Go big or Go home
Originally Posted by Apex Chase View Post
SWEET!!!
Thank you! It's always great to hear positive feedback!
That is my impression also.
Old 10-31-2013, 12:00 PM   #11
Go big or Go home
Obviously being bigger, both the rotors and calipers weigh slightly more. Which may be an issue for those highly concerned with weight reduction but my car already has two 15" subwoofers and 22" wheels so weight concern went out the door a long time ago haha!
Old 10-31-2013, 12:02 PM   #12
Go big or Go home
Thank you! Yes they are. I'm finishing the install tonight so I'll post some pictures of the car completed
Old 10-31-2013, 12:11 PM   #13
Go big or Go home
Those photos are just a rough fitting, everything has been adjusted slightly since but yes, the re-drill does create a slight oval shape. However, the rotor is hub centric so the re-drilling does not effect the integrity at all.
Old 10-31-2013, 02:16 PM   #14
ClawSS
High-tech Redneck
ClawSS's Avatar
Understood. Looks great and could be a nice upgrade. I wonder if just a caliper swap can be done (given bracket et al..) and just pick up a 15" rotor with the appropriate hub...maybe a 2 piece wire locked.
Any idea if these fit on stock wheels?
