Vararam
Old 02-21-2012, 09:16 PM   #15
fmcooper
Drives: 2014 2SS/RS 'Vert
Location: Detroit Metro, Michigan - General Motors Employee
Originally Posted by Blast View Post
I was afraid of that. Hmmm. The question is if there's a way to squeeze in two largeish suitcases in there AND be able to have the top down at the same time or if I'm SOL already on trying to get the two suitcases in.
// Stefan
I put a garment bag under the convertible "shade" in the trunk and fit a standard roll-a-board vertically at the back of the trunk (front of the trunk? anyway, right inside the opening, closest to the license plate).
You could always put a bag in the back seat and one in the trunk when you have the top down I was going to go that route but managed to squeeze the two bags we had in as described above. If you are talking about full size (max dimension) bags, you can fit one in the trunk, but the top will not be able to go down.... and a 2nd one would probably not fit other than in the back seat.
Good choice of rentals by the way
2012 Camaro 2SS/RS Rally Yellow Vert M6 w/Hurst -- 10/20/2011 (My Driveway) (traded in)
2014 Camaro 2SS/RS Summit White Vert M6 w/Perf Exhaust + Perf Shifter -- 08/30/2013(Delivered!)
2016 Corvette Z51 Convertible Laguna Blue -- 06/23/2015 3800
fmcooper is offline   Reply With Quote
Old 02-21-2012, 09:22 PM   #16
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
No way your getting 2 large suitcases in the trunk. The height won't allow it and not large enough side to side. Maybe 1 large and 1 medium bag that can be flexible. In a vert forget it. Get a coupe so you can at least drop the seat down to get larger items into the trunk.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 02-23-2012, 09:25 AM   #17
Blast
Drives: 2009 SAAB 9-5 Aero
Ok .. After a few more hours of information gathering I've come to the following data on the Coupe. The Vert is still a mystery though.
Posting what I've found so that others that search may find it informative (or not, up to them I guess).
WARNING: The numbers are not guaranteed to be exact.
Code:
Trunk Opening:
Width	Rear Edge:	26.5"	67cm
	Front Edge:	30"	76cm
	Max:		33"	83cm
Length (Front>Back):	16"	40cm
Depth (Up>Down):	16.5"	42cm
Inside Trunk:
Width	Max:		53"	134cm
	Wheel wells:	47"	119cm
Length	Normal:		44"	111cm
	Folded Seats:	68"	172cm
Rear seat to trunk opening:
Width:			38"	96cm
Depth (Up>Down):	11"	28cm
Now if anyone here happens to come across a vert with the trunk open and have something to measure with with them - feel free to share. I'll put it in the OP later so that people can find it easily.
// Stefan
Blast is offline   Reply With Quote
convertible, coupe, opening, size, trunk
Any hints on how to remove nuts from inside trunk lid? OHIOSS 5th Gen Camaro SS LS LT General Discussions 25 06-09-2010 10:49 PM
Trunk Size Help! JasonC 5th Gen Camaro SS LS LT General Discussions 15 05-19-2009 09:09 AM
Size of Camaro Trunk? almhath 5th Gen Camaro SS LS LT General Discussions 31 03-23-2009 04:29 PM
Trunk size interrex Camaro Photos | Spyshots | Video | Media Gallery 75 12-17-2008 09:21 PM
Size of Trunk? biddler 5th Gen Camaro SS LS LT General Discussions 17 10-25-2008 03:22 PM
