11-16-2012, 04:53 PM | #1 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
How to: Unpin your ZL1 Rear Upper Shock Wiring
Occasionally we take calls from folks with ZL1's looking for installation tips on how to install drop springs. You can absolutely install our drop spring packages on a ZL1 Mag Ride equipped car, but the procedure is just a little more involved than with a standard V6/V8 vehicle. We do provide instructions for the rest of the process, but this is exactly what is involved in unpinning your Magnetic Ride connector from the shock so you can swap in a drop spring!
So here is exactly how you unpin the Rear Upper Connector:
Hope this helps anyone in the midst of a ZL1 Drop spring installation! This is certainly a cleaner procedure than cutting the connector and resoldering. |
11-16-2012, 05:10 PM | #2 |
Drives: 2000 Camaro SS Join Date: Feb 2010
Outstanding post. Thanks for that.
04-30-2013, 06:20 PM | #3 |
Camaro Addict
Drives: too many Join Date: Sep 2009
maybe sticky this because I looked everywhere for this info and couldn't find it, had to wing it. glad I did it right.
can you verify what wire is top and what one is bottom when they are installed back on the car?
1990 IROC-Z Vert LS
1996 SS Vert LT4 1992 Z28 Z03 T5 1992 Z28 Z03 L98 2018 Sierra Denali 6.2 1997 Z28 Z4C 1995 Z28 |
10-07-2014, 07:16 AM | #4 |
how to Unpin the mrc plug
where did you get your unpin tool, i cant seem to find one around or I'm just not looking in the right stores..
10-07-2014, 07:18 AM | #5 |
Camaro Addict
I made one from a tiny flathead screwdriver. And a grinder.
1990 IROC-Z Vert LS
10-07-2014, 07:25 AM | #6 |
was that your tool in the pictures, or did you grind the round shaft flat and put a little hook to the end?
10-07-2014, 07:40 AM | #7 |
Camaro Addict
The pictures above are not mine. They used the actual tool. I make a small screwdriver smaller to fit the connector plug.
1990 IROC-Z Vert LS
07-15-2016, 06:39 PM | #8 |
Drives: Camaros, BMWs, Cummins, Ninja Join Date: May 2012
OK so been trying at this forever now...how the heck do I unlock those locking tabs ? ?? I'm can't see much inside using a small led flashlight so I just keep digging around in there with a pick and just can't seem to do much of anything ? Do I push down on the pins do I pry the tabs over assuming I can even see them ?
08-28-2016, 06:01 PM | #9 |
Drives: 2013 Victory Red ZL1 M6 Vert Join Date: Sep 2014
This is what i came up with today.
I was unsure of witch hole they referred.
2013 ZL1 M6
Roto Fab CAI, Kooks Long tube Headers with catless connection pipes, 90mm Ported throttle body to match ported supercharger snout. 2.55 upper pulley, Roto Fab intercooler tank, ID 850 injectors, 9.5 mm wires, Custom 93 octane tune. 600 whp. Hotchkis coils. White Collar Grease Monkey https://www.youtube.com/user/gjodexter |
04-23-2017, 11:28 AM | #10 |
Okay...I got the purple tab out. I can't figure out the anatomy to get the connectors loose though. I need some help.
Sent from my iPhone using Tapatalk |
04-23-2017, 11:32 AM | #11 |
Never mind...
04-23-2017, 12:54 PM | #12 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
This was a pain in the ass when I did mine....
It's been so long ago I forgot how I did it. lol
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
04-23-2017, 12:59 PM | #13 |
You just pop them up and then push them back a little to get them started on their way out.
04-23-2017, 01:00 PM | #14 |
These Pfadt springs look every bit a tall as my factory springs. I hope they lower the car because I'm not silly about messing with these pins again.
