dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 06-05-2011, 07:21 AM   #1
CamaroBelarus
Drives: black 2SS
Is it AFM?
Hello. Sorry about wrong topic title. I ment Torque Management, not Fuel management.
There is a problem. If its a problem
I have ss ls3. When trying to do fast 0-60 run, seems there is a huge lag on 1st gear.
The order im doing: 1st gear, pushing clutch and getting to about 1.5-2k rpm, then releasing the clutch pedal. A little wheel spin and car jumping to 30mph, then engine just stops rev higher for time like 0.5-1 sec , then its going higher and i switch to 2nd gear at 5-5.5k rpm and 45mph. Is it torque management here cos of too agressive shift?? Is it so agressive on manual? Or there is a trouble with smth? TC on , launch control not using.
Thanks.
CamaroBelarus is offline   Reply With Quote
Old 06-05-2011, 07:23 AM   #2
coolman
Guest
An LS3 doesn't have AFM. Only L99 with the automatic have AFM.
coolman is offline   Reply With Quote
Old 06-05-2011, 08:18 AM   #3
CamaroBelarus
Drives: black 2SS
deleted
Old 06-05-2011, 08:22 AM   #4
coolman
Guest
Originally Posted by CamaroBelarus View Post
No, i think ive read ls3 have AFM as well. So, if u think its not AFM, where is the problem?
You read wrong. The LS3 doesn't have AFM.
To answer your question, I would say it might be the driver.
Old 06-05-2011, 08:52 AM   #5
CamaroBelarus
Drives: black 2SS
Yeah i was wrong, sorry, but is there a system like Torque management? Can it be a problem? LS3 engine torque is limited below 3000 RPM, maybe i have a lag cos of it?
About driver mod - well, what am i doing wrong then? I had 4 manual cars before and never had such problem?
Old 06-05-2011, 10:36 AM   #6
CamaroBelarus
Drives: black 2SS
It feels like smth backs off the throttle. Anyone?
Old 06-05-2011, 02:04 PM   #7
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Did you turn off the traction control? Turn it off and try again.
Old 06-06-2011, 08:03 AM   #8
CamaroBelarus
Drives: black 2SS
I just tryed with TC off, with stalbiltrac off and in competition mode, when u push TC button twice. Nothing changed. Seems when im launching from 0rpm, car jumps to like 2.5k rpm, then even DROp it to 1.5r rpm, and only after that its pushing...:(
Old 06-06-2011, 08:05 AM   #9
anthonyj9h
"First There"
anthonyj9h's Avatar
Drives: 2010 camaro 2ss
sounds like you are slipping the clutch and not letting it out all the way
Originally Posted by jewel25 View Post
No one wants to be like aytard. He is a douche for eggs.
it is written......
anthonyj9h is offline   Reply With Quote
Old 06-06-2011, 11:32 AM   #10
CamaroBelarus
Drives: black 2SS
Okey, had a time and tried everything i could. launch from 0 rpm, car launches, then lag like 0.5s and rpm dropping from 2.5k to 1.5k, then it pulls. Tried launch from 2k rpm - same. Tried to drop clutch pedal fast - same. Tried to drop clutch slowly - same. It cant be me. Tried every variation...
As the last step - tried launch control... Got it to competition mode. Fully pressed clutch. Got it to 1st gear. Pushed gas pedal. Somewhere on 5k released the clutch. Car launched, BUT clutch pedal left on its place! Fully pressed. WTF? Even burning clutch smell was around. Anything wrong here?
Old 06-06-2011, 11:44 AM   #11
anthonyj9h
"First There"
anthonyj9h's Avatar
u are going to have some drop because you are mating the engine with the transmission so naturally its going to drop and then the rpms climb.....take it to the dealer and see if something is wrong with your peddle
it is written......
Old 06-06-2011, 12:37 PM   #12
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
how are you launching from 0 rpm?
I piss excellence
and fart awesomeness
Old 06-06-2011, 02:33 PM   #13
CamaroBelarus
Drives: black 2SS
Clutch to the floor, starting to releasing it wile pushing gas pedal. All basics.
Old 06-06-2011, 02:46 PM   #14
CamaroSpike23
Truth Enforcer
thats what I assumed,
but you said "launch from 0 rpm".
which if read literally, you are either trying to launch the car with it turned off, or starting the car and immediately releasing the clutch.
just trying to clear things up.
I piss excellence
L99 VVT / AFM Camshaft Dyno Results & Explanations Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 90 11-27-2010 08:21 PM
5 of your biggest complaints with the Camaro Audioi 5th Gen Camaro SS LS LT General Discussions 180 01-16-2010 12:35 PM
Just got off the phone with Borla! L99 + AFM look here HeavyD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 09-17-2009 02:05 PM
Competition CAMS nearly ready to release their L99 cams for the VVT AND AFM! PatrickfromMD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 32 07-30-2009 05:46 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
