07-27-2021, 11:23 AM | #1 |
Drives: 2012 2LT 45th anniversary convert Join Date: Apr 2012
Open latch message
When I unlatch the top, and press the button to lower the top, I get a message on the dash that says "unlatch top" even though it is already unlatched. The dealership says it needs a whole new latch mechanism which is $459 installed. This seems high. Does the whole mechanism need to be replaced, or is there some less expensive way to fix this?
07-27-2021, 05:55 PM | #2 |
Drives: 2015 Topless Btch RS Join Date: Mar 2016
Have a look a this
07-27-2021, 06:34 PM | #3 |
Thanks for the info, but this seems to be the opposite of what I have. This is saying "top not secure" when the top is up. My top won't go down.
07-27-2021, 06:55 PM | #4 |
Drives: 11 camaro 2lt rs Join Date: May 2008
Clean out the micro switch area maybe? Maybe some debris preventing movement?
07-28-2021, 05:27 PM | #5 |
Thanks. I will see if anything can be done with that. But the top won't go down, so I don't think I can get in there.
09-06-2021, 11:32 AM | #6 |
Drives: 2014 Camaro RS 2LT convertible Join Date: Jul 2020
Can we manually lower or raise (gulp!) the tops?
Sent from my iPhone using Tapatalk |
09-06-2021, 04:00 PM | #7 |
Drives: 2013 zl1 vert Join Date: Dec 2018
Yea you can manually open the top. The car should of came with the tool to do so. There is a spot between the seat for the tool.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
