10-10-2023, 02:28 PM | #15 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I think you'd really have to crank on it to strip it especially by hand, by the time you put a wrench on it you should know.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
11-04-2023, 05:58 AM | #16 | ||
11-04-2023, 10:34 AM | #17 | |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
What does make a difference if you are having trouble bleeding air out with a separate clutch reservoir is putting vacuum on hole at the bottom of the reservoir. There are probably better ways to bleed the clutch master cylinder, but that worked for me when air kept leaking past the stock bleeder valve. Those bleeder line extensions with the one-way bleeder valve are really worth every penny.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
11-04-2023, 12:54 PM | #18 | |
11-05-2023, 06:34 AM | #19 |
Probably true, but just don't see the need for the syringe.
12-04-2023, 07:07 PM | #20 |
Drives: 2014 1ss camaro Join Date: Jul 2017
i have the remote bleed and do the ranger method quite often. its easy suck out resevior with one of those 2 cycle syringes at walmart. refill with freash fluid pump pedal slowly 15 to 20 pumps all the way up and all the way to the floor. suck out the resevior refill with fresh. repeat the pump procedure. i pumped it out about 6 times it definetly works i put the old stuff in a clear glass jar to look at and used a magnifying glass to look closer it does work even if my spelling doesnt.
12-05-2023, 07:09 AM | #21 | |
