Roto-Fab
Old 07-27-2017, 10:12 PM   #1
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
1LE cradle bushings
Does a 1LE have different cradle bushings than a regular SS?
zz430camaro is offline   Reply With Quote
Old 07-28-2017, 04:14 AM   #2
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Drives: Kami, 2013 2SS LS3 Luvin
Send a message via MSN to Scott@Bjorn3D
Yes, the are much firmer but you can get stiffer ones. When I had the 1LE track pack installed on my car it really help cut down on wheel hop.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-28-2017, 08:23 AM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Get solids from one of the vendors you won't be disappointed!!
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 07-28-2017, 08:57 AM   #4
zz430camaro
Drives: 2015 1LE
I have a 1LE and wanted to upgrade the subframe bushings and was trying to decide on poly or solid. Sounds like most people recommend solid. Even though these dont transmit much NVH I was wondering how it will get with aftermarket trailing arms with poly bushings.
Old 07-28-2017, 10:44 AM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
I would get Solids!
However, remember if you replace your Cradle or Diff Bushings, there is no way to go back without buying a New Cradle
Old 07-28-2017, 11:02 AM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
You shouldn't see any NVH till you do diff Bushings and only minor on arms.
Orange Krush II
Old 07-28-2017, 11:19 AM   #7
zz430camaro
Drives: 2015 1LE
Solid it is!
