02-19-2018, 10:33 AM | #71 | |
Drives: 2016 1SS - M6 Join Date: Jun 2017
I have always used something similar to the above, only I use a 2 x 4 roughly 8" long. The wood gives the jack (or the stand) something to disburse the weight more evenly further out than even the wide pad jack - but I still use the wide pad jack just the same Do know though, that I will NOT use those areas as the main support for prolonged rest (ie over an hour) Thought that I would just throw that out there as an option |
02-19-2018, 11:11 AM | #72 | |
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel Join Date: Oct 2017
02-19-2018, 01:30 PM | #73 |
Drives: 2013 C6Z06 Join Date: Nov 2016
I was using a cheap jack and their universal jack pad. Old concrete, jack didn't roll properly to stay vertical, jack pad went crooked and slipped. Needless to say that won't ever happen again...
02-19-2018, 02:15 PM | #74 |
02-19-2018, 02:19 PM | #75 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
I use this. Self made.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
02-19-2018, 03:32 PM | #76 |
Drives: 2016 2SS Red Hot Join Date: May 2016
Not so sure if the only concern was the make up of the material in the location. I believe, and may be wrong, that another concern was the overall thickness of the material there and its inherent strength. Just because it is "magnetic" doesn't mean it was designed to support the weight of the vehicle. In the end of the day its your car, your choice. As mentioned above I have had the dealer use my pinch points stating the GEN6 is like the Corvette and requires it. And yes, to be fair and open, I also bought the jack pads.
2SS, A8, NPP, Nav, Sun Roof, Bose Audio, MM Catch Can, RPI chin splitter |
02-19-2018, 05:20 PM | #77 |
Drives: 2018 Camaro 2SS Redline Convertible Join Date: May 2016
I've have excellent results with my Zl1Addons magnetic pads on my Gen 5 Z28 and my 2018 SS Redline convertible. I since have purchased the Bolt On pads from ZL1 Addons and love em.
2019 Buick TourX
2017 Colorado Redline 1966 Ford Mustang Pro Touring |
02-19-2018, 05:41 PM | #78 |
Drives: 2017 A10 ZL1 KG Join Date: Oct 2014
I’ve read several instances from damage resulting from not using the pinch weld points. Use the pinch weld points.
02-19-2018, 09:40 PM | #79 | |
Drives: 2017 2SS convertible M6, NPP, MRC Join Date: May 2013
Did you hear about the restaurant on the moon?
Great food ------ No atmosphere. |
02-19-2018, 09:47 PM | #80 |
Thank you Al Oppenheiser!
On the vert there is only one forward pinch weld you can lift with on each side.
So lift with it. Use a slotted puck or zl1addon lift point to reduce the possibility of buckling the pinch weld. Then put the stand under the bolts on the forward x-brace right next to where you jacked. Once you try it, you’ll realize there really is only one way. http://www.camaro6.com/forums/showthread.php?t=473325 http://www.camaro6.com/forums/showthread.php?t=471737 |
02-20-2018, 04:25 AM | #81 | |
http://www.camaro6.com/forums/showth...hlight=chicken
2019 Buick TourX
02-22-2018, 10:34 AM | #82 |
Drives: 2016 SS Join Date: Mar 2016
Personally, I bought 2 quality floor jacks from Costco ($100 ea), and ordered two of the rubber hockey puck jack pads for use at the factory pinch weld jacking points. When I have to jack up the cars for whatever reason, typically to change tires/snow tires, I jack simultaneously from both sides or from front/rear, this minimizes twist against the frame and also means I can change two tires at a time etc. Works good and when lifting from front and rear I can easily operate both jacks at the same time by myself.
02-23-2018, 02:00 PM | #83 |
Drives: 2017 2SS M6 FIFTY @51fifft Join Date: May 2017
I would bet the aluminum brace right where the bolt is, that's way stronger than the thin ass sheet metal where the magnet is stuck. IMO if you don't have the jack pads from ZL1 that's the spot in the front on each side i would and have used, in the rear i just jack it from the center section. Changing a tire I use the always on the car added jack pads.
If you have half a brain and use common sense ( rare these days ) it's not rocket science!
02-26-2018, 12:47 AM | #84 |
2018 1LE, NASA Instructor
Drives: 2018 Camaro SS 1LE Join Date: Jan 2018
I'm new to Camaro - Just bought my 1LE last week, but been doing track prep of previous cars (C7 Z51, Mustang GT, etc). I've been reading this forum to gain insight, but still a Camaro newbie for sure.
Having said that, a few observations on videos and postings I've seen here of the ZL1 magnetic pinch weld adapter. 1 - Why use that to jack the car up, but then drop the pinch weld on a bare metal jack stand? Not knowing better, I ordered the rubber cover below for my jack stands. Any opinions? https://www.amazon.com/Compatible-Mo...V6HHNJH58NS0ZN 2 - The ZL1 magnetic adapters don't look safe to me at all. They are wobbly, move around and I can see a slightly misplaced jack pad to cause them to buckle on one side or slip off. I could be wrong, but boy those scare me. I did a test lift with flat hockey puck as well as the notched taller rubber pucks I had on hand and they worked great on pinch weld. https://www.amazon.com/DEDC-Universa...s=jacking+puck 3 - I did not like the fact that the weight of an entire half of the car is only on one pinch weld while jacking from the side (i.e. both wheels came off the ground. I have 2 jacks so, I'd be jacking using 2 jacks (jacking a little at a time from each). This way I can lift either side, full front or full back completely. Seems like much less stress on the vehicles and the pinch weld. Thoughts? 4 - Question, not Camaro specific. When lifting both rear (e.g. to rotate tires side to side) are just front wheel chocks safe enough to prevent the car from rolling? Thanks - and again, not claiming to have any insight, just sharing my thoughts, in the hopes it may help others. Last edited by baron95; 02-27-2018 at 05:23 PM. |
