Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 10-09-2016, 01:10 PM   #1
jasycz28
J.Sick
jasycz28's Avatar
Drives: 2010 Camaro SS
Need help with Carlyle racing 15" setup. Rubbing!!
I have a 2010 Camaro with Pfadt lowering springs, Carlyle racing 15" wheel kit, 15" Welds from Carlyle racing, and ET Street R Bias 28X11.50-15LT. This is my end result. Everything fits and clears fine with the suspension unloaded. Is it because I am lowered?
"J.Sick"
2010 Camaro 2SS
jasycz28 is offline   Reply With Quote
Old 10-09-2016, 01:54 PM   #2
1709
9.56@144.09
Drives: 2013 zl1 black
Not sure. put an 3/16 wheel spacer on and that should give you enough room. you will have to put on longer wheel studs. I have carlyles 15 inch kit and that is what I do.
1709 is offline   Reply With Quote
Old 10-09-2016, 10:27 PM   #3
canecorso69
run ur car not ur mouth
canecorso69's Avatar
Drives: 2013 1LE
I have carlyle kit and 15" welds. Im lowered 1.25" on Pfadt springs. I run a 275 60 with no issues. I tried a 325 50 and it hit the lower control arm. The 275 is ~10" wide and the 325 is ~ 11" wide. I would say your tires are too wide.
TSP headers, cat delete, x-pipe, atak, RPM custom cam and tune, Phfadt 1.25 springs, 15" Carlyle conversion, Nitrous Outlet, Procharger F1A-94, Meth inj
canecorso69 is offline   Reply With Quote
Old 10-09-2016, 10:37 PM   #4
1709
9.56@144.09
The R bias 28x11.50-15LT is only 8.8 wide. not sure what is wrong. with the 3/16 spacer I run a hoosier 29x10.5W slick which is 11 inches wide with no problems. have done 1.41 60 foots and 9.56@144mph in the 1/4 mile.
Old 10-09-2016, 10:56 PM   #5
canecorso69
Drives: 2013 1LE
Good info. After looking closely at pic it looks like the actual wheel is hitting the LCA.
Old 10-09-2016, 11:09 PM   #6
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
What do you mean by lowered? You are lower than stock?
I am running MC kit + Welds or Race Stars in the back. Both clear no problem.
I'll look for a good pic, but right now I have my car pretty low in back.
Measure from the center of the rear fender lip to the ground... 29 inches?
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 10-10-2016, 12:09 AM   #7
BrainleSS
Working on my 2nd one!
BrainleSS's Avatar
Drives: Camaro
Call Mark 888-307-9186
[SIGPIC][/SIGPIC]
BrainleSS is offline   Reply With Quote
Old 10-10-2016, 12:02 PM   #8
jasycz28
J.Sick
jasycz28's Avatar
I will have to measure when I get a chance. By lowered I mean I am on Pfadt lowering springs.
I will also call Carlyle when I get a chance. I was just seeing if anybody else was having the same issue or not.
Another question. Where are you guys placing your wheel weights?
"J.Sick"
2010 Camaro 2SS
Old 10-10-2016, 12:16 PM   #9
canecorso69
Drives: 2013 1LE
I placed mine on the inside side of the wheel. I had them on the outside side of the wheel and they hit the calipers.
Sent from my SM-G935V using Tapatalk
Old 10-10-2016, 02:17 PM   #10
Pro Stock John
Writer
can't put wheel weights on the back of the inside barrel.
PROJECT HEAVY CHEVY
Old 10-12-2016, 02:09 AM   #11
ThaCamaroKid
ThaCamaroKid's Avatar
Drives: 2010 Camaro 2SS/RS L99
Well this is interesting... Buying these LCA's soon, haven't seen this issue before though...
375RWHP/399RWTQ
ThaCamaroKid is offline   Reply With Quote
Old 10-12-2016, 12:11 PM   #12
Pro Stock John
Writer
How low is OP's car? Really slammed?
PROJECT HEAVY CHEVY
Old 10-12-2016, 06:05 PM   #13
jasycz28
J.Sick
jasycz28's Avatar
I will take some measurements tonight and we will see how low compared to others. Carlyle said I was the first to have an issue he thinks I am too low as well. I am going to send him more pics when I get a chance. I am in the process of packing and getting ready to move so time is limited.
"J.Sick"
2010 Camaro 2SS
Old 10-13-2016, 12:56 AM   #14
jasycz28
J.Sick
jasycz28's Avatar
So where then?
"J.Sick"
2010 Camaro 2SS
