dave@hennessey
Old 10-07-2016, 04:29 AM   #1
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
what cylinder heads for 1000whp
what cylinder heads should I run for my new setup?
I'm leaning towards a set of lsa heads for the thicker casting?
should I run them as cast or do I need to have them ported to get rid of the "batwing" in the intake runners? plus should I have inconel exhaust valves added?
or even cheaper yet, reusing my gmpp ported ls3s?
just don't want issues and would like to hold a headgasket at this power level. my head is spinning(can you tell?)
408-416ci
twin garrett 6265s
e85
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 10-07-2016, 06:26 AM   #2
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
I'm running my stock LS3 heads with ls9 gaskets and ARP studs. Hard to get quality information sometimes on forums just because people seem to think if it's not a built LSX it won't make 1000+whp.
Are the ls3 heads optimal for 1000whp? Not really they do have much better options if money is no issue.
A couple Camaros here are at the 1000whp mark on stock bottom end still.
I'll be other 1000whp but 98% of the time it will be turned down because let's face it. 1000whp and 4000lbs is going to have traction problems. Lol
If your budget allows for better heads go for it. If not keep what you have just add ls9 gaskets and ARP studs at the minimal.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 10-07-2016, 06:36 AM   #3
ttshovel
ttshovel's Avatar
I know there is plenty of untouched motors at 1000whp. but I'm looking to get years out of this motor and not have to worry about dropping or breaking a valve. I've heard mixed things like at minimum to have the intake ports cleaned up and to have the inconel exhaust valves or a solid valve that can handle the heat
Old 10-07-2016, 06:58 AM   #4
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Get the stock head's dykm'd to check for cracks first....then deck'd for a nice flat surface, new solid valves with valve job, (if you can get the chamber volumes equalized), basic port match on intake/exhaust and as mentioned above LS9 hd gasket and studs...solid investment of monies and extra funds go to any drive train issues that arise(and they will with that HP!!!!!)
have fun..stay safe...peace out...
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 10-07-2016, 07:05 AM   #5
Unreal
Drives: 2006 Z06
If budget allows LSA/ls9 heads are a great upgrade. Get a mild port job, proper valves and springs. That is one area that you should spend money in.
While stock heads can work, long term reliability and safety factor is much lower.
If you can't afford a cheap set of LSA heads, you can't afford 1000rwhp.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 10-07-2016, 07:24 AM   #6
ttshovel
ttshovel's Avatar
I'm ordering the turbo kit Monday. and I'll have enough left over after the part out is said and done that I can buy a set of lsa heads. I'll probably call thompson motorsports and see if they have cores and go that route. I don't want to second guess myself on anything!
Old 10-07-2016, 07:35 AM   #7
frankwjr
frankwjr's Avatar
Well if I had a barrel of cash then lol...OP did state cheaper alternative...only lookin at the 2010 twin turbo camaro runnin 7's with stock LS3 heads....seems they hold up ok there...
Old 10-07-2016, 07:38 AM   #8
ttshovel
ttshovel's Avatar
you misread that then. I asked if my heads would suffice or if I needed to get the other castings and work done as stated. and as I figured, I need the lsa heads.
and I was looking for answers from people that have first hand experience with cars of this caliber
Old 10-07-2016, 08:06 AM   #9
frankwjr
frankwjr's Avatar
well excuse me...
Old 10-07-2016, 08:08 AM   #10
frankwjr
frankwjr's Avatar
oh and btw - you have no clue about my exper...if you based it on my sig? rofl...30+ years hands on auto plus common sense equals = you get the pic...peace out
Old 10-07-2016, 09:26 AM   #11
Unreal
Drives: 2006 Z06
Wise idea. Plenty of places people waste money, but things like fuel system and a solid head setup for a 1000+hp build will lead to a trouble free reliable setup. You don't need to worry about porting/etc if you don't want to, as that isn't needed but getting a stronger casting/thicker deck/etc is well worth it in that range.
Nick
Old 10-07-2016, 09:29 AM   #12
ttshovel
ttshovel's Avatar
exactly why it was weighing on my mind! thanks for the advise as always!!!
Old 10-07-2016, 11:17 AM   #13
Livernois Motorsports
Livernois Motorsports's Avatar
Drives: 2010 Camaro 454 LSX (SOLD)
We have plenty of Camaro Head options to suit your 1000hp+ build!
Our Powerstorm GM LSA Race Series heads are built with the highest quality components on the market to date! These head packages are built around Livernois years of racing experience and combine all the knowledge of our extensive development background as well. This is how we're able to offer cylinder head packages that are unmatched in their performance.
What you'll find with this head:
5 axis CNC machined
Fully assembled
Custom valve job
Upgraded stainless steel intake & exhaust valves
Upgraded springs
Upgraded retainers, locks and seals
GM Guide
Available HERE!http://www.livernoismotorsports.com/product/LPP761108
Combining this head with our Inconel Exhaust Valve Upgrade, you'll be putting down the power in no time.
We also have our LSX - LS9 Race Heads that would do a great job as well!
For any other questions, give us a call at (313)-561-5500 ext: 1 or email us at info@livernoismotorsports.com
Livernois Motorsports is offline   Reply With Quote
Old 10-07-2016, 11:18 AM   #14
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I have the LSA heads with a port and polish job done by ADM. It's a good set up.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq
10aSSee D is offline   Reply With Quote
