07-23-2015, 08:37 PM | #15 |
Drives: Jeep Wrangler Join Date: May 2015
Yeah, the LS7 mention doesn't seem plausible. Would the LS7 even pass emissions under 2016+ regulations?
I just get a tingle anytime someone mentions a 6th gen Z |
07-23-2015, 08:41 PM | #16 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
The LS7 is dead...let it rest in peace.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
07-23-2015, 10:57 PM | #17 |
Drives: 2007 Corvette Z51 Join Date: Jul 2015
Did the Z/28 have the same LS7 heads issues as the Z06?
07-23-2015, 11:33 PM | #18 |
Drives: Current Camaro-less Join Date: Jul 2014
07-23-2015, 11:38 PM | #19 |
Then good riddance if it's gone. Sounds like it's time for the LT2/LT3. (To wedge between the 1 and 4 )
07-24-2015, 02:50 AM | #20 |
Drives: El camino Join Date: Nov 2014
Amen.
The lack of a high strung LT7(or equivalent) will also show if the emmision requirements have found the limits of single cam v8's.. So far the architecture has put a hurting on the competition for many years but in the realm of high revving engines it's possible the design has reached it's limit in production vehicles.. Exciting times ahead, thats for sure. |
07-24-2015, 11:58 AM | #21 | |
Drives: RS Join Date: Jan 2013
While we are speculating, how about a short stroke 5.7L LT1/LTX built like the LS7 that is high revving and makes about 530HP. Maybe using both DI and PFI. |
07-24-2015, 12:06 PM | #22 | |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
07-24-2015, 12:18 PM | #23 |
Drives: 2005 Cobalt Base - 5 speed Join Date: Apr 2015
I really don't think they'll merge the two cars, as they're very different. Z/28 is a hardcore track car and ZL1 is a high powered grand touring car (or whatever you want to call it). Whereas the Z06 was high performance and the ZR1 was highest performance. Merging the Z/28 and ZL1 would compromise the spirit of one or both cars. You'd either have a slightly more track focused ZL1 (carbon ceramic brakes, is one example) or a more touring focused Z/28 (softer suspension not optimized for the track like the current Z/28, no optional air conditioning / radio, no weight reduction over the base SS, heated and cooled seats, etc) depending on how you look at it. I don't think the buyer of a ZL1 necessarily wants a Z/28, and vice versa. I think they're both very good at what they do and should continue to be separate cars in their own right.
07-24-2015, 12:36 PM | #24 | |
The C5 and C6 Z cars were both "NA track monsters" and GM still combined them into the C7 Z06. The Camaro isn't special enough to avoid a fate that the Corvette couldn't |
07-24-2015, 12:39 PM | #25 | |
The C7 Z06 is a complete departure from the previous generations. Our hope is the people who stopped the ZL1 from being the Z/28 can keep it from happening this generation.
07-24-2015, 01:10 PM | #26 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Do one of two things:
1) Offer a ZL1 with the LT4 and try their best to put it in the 55 - low 60K range and make it an all around car like the 5th gen ZL1. Then offer another track monster, low volume Z/28 with an n/a engine. 2) Go Fords route, except using the LT4 instead of an n/a engine and offer lots of varying packages for the Z/28, starting with a "tour" model in the range mentioned above with creature comforts, to a more hardcore model utilizing track suspension, cooling, weight savings costing considerably higher than the "base" Z/28 car.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
07-24-2015, 01:11 PM | #27 |
If there is only one, the Z/28 will be dropped and the ZL1 will continue based on Al O's views on what the Z/28 should be.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
07-24-2015, 01:34 PM | #28 | |
Moderator.ca
And keep in mind, the Z/28 as we know it wasn't really part of the plan on the 5th gen. Not at the beginning at least. When the ZL1 was under development, it was intended to be a Z28. The name was changed shortly before it debuted in 2011, at the insistence of Z/28 loyalists within the Camaro team. Only after that did they decide to do a true Z/28.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
