Old 11-24-2019, 07:10 PM   #29
LARRY01Z28
Drives: 2001Camaro Z28
im going to this next year. I raced cecil and MIR all the time when I was stationed over there. in my 01Z28 I set the number two spot for bolt on M6 at MIR. Cecil hooks great.
LARRY01Z28 is offline   Reply With Quote
Old 11-26-2019, 07:52 PM   #30
JimW
JimW's Avatar
Drives: 2011 Camaro
Nick (guitarmegedden) just went 8.89@160 with his twin turbo Gen6 Zl1 and did it with 17" Rs and stock Zl1 fronts. That's Z is bad for sure. Everybody has really picked up their game this year. Gen6's are starting to rule the roost. Yes a little spray off the launch will spool that baby for sure. Mines not legal but safer then most with the RPM Roll Bar with swing out door. My buddy got kicked off our local track when he ran 9.72@144 with his Gen6 Maggie Camaro. Told him to slow it down or don't come back. They always passed mine thru with the RPM Bar, they know I have a belly pan to catch oil, loop, axles and DS plus the harnesses and extinguisher in the car. I feel it could take a pretty big hit and I'd be safe in the car. I do need to get a full faced helmet for next year and upgrade my jacket and pants to NHRA spec.
My car and nicks are out of the same shop .. cspracing.com .. I’m still stock block and stock trans ..(ATI low stall converter) guess I’m the budget build .. still does daily driver duty ... other then idle .. drives stock .... I swap my skinnies and stock front wheels out a lot .. not much difference in weight .. I run skinnies cause the car tends to sway less on the big end when rear tire pressure is low .. I’m also on 17 et r’s rears.
I was going to 8.50 cage and Shute mine .. but I think I will wait till they kick me ..
150s on the big end is crazy .. can’t wait to see what it’s like at 160.
2017 Garnet red ZL1 A10 Procharged LME 427 L8T
JimW is offline   Reply With Quote
Old 11-26-2019, 11:03 PM   #31
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
My 149.82 was so close but it just didn't happen. Conditions were right and I just couldn't get there. My 1-2 shift just wasn't on time and then short shifted to 3rd and you could here it on the video and my et just was slower then my quickest. Hey there is always next spring cause here in the Midwest the tracks are closed. I know my car will run 9.20s at 150 but its all got to click at the same time, one time it didn't hook, then it didn't shift so WTF? Haha its all good.
Old 12-05-2019, 04:17 AM   #32
6spdhyperblue
Drives: 6th gen
Do you have the drag cal for the elsd?
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
Old 12-26-2019, 10:45 AM   #33
JimW
JimW's Avatar
Drives: 2011 Camaro
Yes the gm drag calibration was flashed on mine...
