Old 06-21-2018, 03:41 PM   #29
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
They are a straight drag racing wheel. They dont have the strength to go through corners at 70 mph on the highway, or take the pounding of pot holes. You will probably crack the barrel on the wheel if you drive it on the street in a daily basis.
Some things say "not for street use" for legality purposes... like off road connection pipes. Drag racing wheels are not the case.
You might get lucky and they might hold up.... but if you dont.... weld wont warranty them
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 06-21-2018, 03:43 PM   #30
Black Hole
Drives: 2017 2SS Redline
Well, thanks for saving me. Shame - those wheels look amazing.
Black Hole is offline   Reply With Quote
Old 06-21-2018, 03:52 PM   #31
ULTRAZLS1
ULTRAZLS1's Avatar
I thought the stock wheels/tires are about 27.5 but not positive
Some of the drag wheels are not for street use because they are built so light and or thin. They are not structurally strong enough to handle potholes or very rough roads with sufficient reliability.
There’s a very good chance you will ruin a drag only wheel if you drive it on the street. And I personally would not take that chance at over a grand per wheel. The roads in Michigan no way in hell I would try it
Still plenty of light street strip options and they aren’t nearly as pricey. I’m looking at the billet specialty win lite. A 15x4 is 10 lbs and a 15x10 is 14 lbs. still plenty light and you can daily them. Around 350-450 per wheel depending on size if they are 15s. 17s are 550 range
Old 06-21-2018, 04:07 PM   #32
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Guys his tuner is not the only one frowning on E85 conversions. I had a local tuner that I thought was main stream and progressive tell me "he does not offer flex fuel tuning". He stated that "he felt that E85 was corrosive and doesn't like to sit. Gums up fuel systems too quick" I told him I wouldn't be leaving it in long durations, and would only run it when going to the tracks (drag/road course) in quantities only needed for each event. Otherwise will be right back on pump 93. Needless to say I am, and was not, impressed. I've yet to install my DSX Kit, but I most certainly will be very soon!!! And, if I can get the help technologically, I may very well be looking to PRAY (re-enlist) once again to go the remote tune route. IDK
driven2exceSS is offline   Reply With Quote
Old 06-21-2018, 04:35 PM   #33
ULTRAZLS1
ULTRAZLS1's Avatar
The corrosive problem applies to older vehicles before the flex era. Long story short the fuel systems in those older vehicles will be corroded by the e85. the Camaro is not one of those vehicles.
Old 06-21-2018, 04:48 PM   #34
danhr
BAMF SS
danhr's Avatar
That is extremely surprising... especially considering your local tuner (you are correct, he is VERY mainstream).
Stock Longblock
Old 06-21-2018, 09:56 PM   #35
parish8
Drives: 17 SS a8
Originally Posted by Black Hole View Post
@parish8 - hope you mean 6.48 on stock wheels, not "motor."
Car was stock from the cylinder heads to the 20” rims. Stock motor, stock converter, stock trans, stock driveshaft, rear, axles, rims. Lots of stuff on top of the motor.
Old 06-22-2018, 04:34 AM   #36
PRAY
PRAY's Avatar
Drives: 2016 2SS
All I will say is that I am doing a H/C job on a car now that has basically only seen E and it is the cleanest motor I have ever taken apart. Everything in side looks amazing. The pump gas motors I take apart look like crap.
Old 06-22-2018, 07:23 AM   #37
ULTRAZLS1
ULTRAZLS1's Avatar
Yeah I’ve always assumed it burned cleaner. Never heard of the gumming up thing. One of the only negatives I’ve heard is that E85 will collect moisture long term more than regular fuel
Old 06-22-2018, 07:42 AM   #38
driven2exceSS
Sorry OP... I am 100% sold on E85, the tuner I spoke of was the first I heard of anyone claiming any negative (other than E85's availability locally). Hearing of the OP's situation it provoked me to comment is all. Just to be clear, my delay on my install has NOTHING to do with those views at all. Absolutely looking forward to the gains!! Only regret/concern I can see anyone having is wishing it was done earlier when the flex kit was first made available!!
Old 06-22-2018, 07:55 AM   #39
danhr
BAMF SS
danhr's Avatar
I love the fact that I cleaned and polished the inside and outside of my exhaust tips the day after I got tuned for e85...... they are still just as clean and shiney. No carbon or anything
Stock Longblock
Old 06-22-2018, 08:10 AM   #40
Chevy71
Chevy71's Avatar
Drives: 2016 2SS
The inside of your motor looks just as good too. It does wonders for a motor!
2016 2SS/Hyper Blue/M6/NPP/Navi
Forged pistons
Custom cut Brian Tooley Cam
SW long tube headers
3" stainless mid pipe - Secondary Cat delete - High flow cats
Port and polished heads-Double valve springs-platinum lifters & push rods
Cam phaser limiter - DOD delete
P1SC-1 Pro Charger 3.7 pulley
Stage II intercooler
667rwhp 577ft lbs
Chevy71 is offline   Reply With Quote
Old 06-22-2018, 08:13 AM   #41
danhr
BAMF SS
danhr's Avatar
Yeah but I dont clean the inside of my engine before a car cruise/car sbow. Lol.
Stock Longblock
Old 06-22-2018, 09:03 AM   #42
Black Hole
OK - I'm back on the e85 train; I have 2 other tuners in the area to check out. Now, back to the drag radials...LOL.
