03-06-2016, 08:10 PM | #29 |
Drives: SS 6 speed of course Join Date: Jan 2016
Sounds like my local track. Good luck, The A8 is easier to launch.
03-06-2016, 08:13 PM | #30 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
I mentioned stock car, prepped track a few times as well. A crappy track, or modded car will of course need a tire, I totally agree there. Fact is there are many good tracks that prep well. Both I use prep well even on test and tune nights. I had zero issues with traction with my previous automatic Coyote. Even with all season, factory tires and a tune and exhaust work. I even for the heck of it tried a friends drag radials, since I had no traction issues, there was no gains. I am a long time member of S197, which is far more busy than here, and at least weekly someone is complaining about no gains after doing a tire. Then we find out they have an auto that is hooking well lol. Even with the aggressive transmission gearing, it's the final drive ratio/rear gears that takes the initial hit, remember. All I am saying is before anyone buys a tire, test first at your local track. If it's good and prepped you may not need a set. Simple as that... |
03-06-2016, 08:19 PM | #31 | |
03-06-2016, 08:23 PM | #32 |
マスタング = 遅い
03-06-2016, 11:10 PM | #33 |
Drives: 2002 ws6 Join Date: Jul 2009
Coyote is also weak sauce on the low end
Bolt on 2002 ls1 Trans am--- 11.5 @ 121 (1.72) 2000 da
03-07-2016, 07:31 AM | #34 |
マスタング = 遅い
03-10-2016, 11:48 AM | #35 | |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
One of my rear sets of rims for my 2010:
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
03-10-2016, 02:23 PM | #36 | |
Owning SSes for 50 Years
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 |
03-10-2016, 02:42 PM | #37 |
Drives: Current Camaro-less Join Date: Jul 2014
With absolutely, totally, unnaturally good track prep?...yeah a street tire *should* hook as well as a DR.
However, DR's make up for a less than perfect track. They help mitigate the variables of temperature (track getting cold/hot) and track surface irregularities. If you're wavering between getting wheels and DR's..the answer should be yes. |
03-10-2016, 08:11 PM | #38 | |
03-10-2016, 08:50 PM | #39 | ||
Drives: 2016 Camaro 1SS A8 Join Date: Jan 2016
2016 1SS A8
7.9 @ 90.79 Stock with a tire 7.20 @ 94.71 LBO getting kicked out Now tuned on E85, CA Performance Test pipes & Circle 4C 3800 stall shooting for low 7's next time out. |
03-10-2016, 09:30 PM | #40 | |
When you have no TPMS for the rear rims, do you have to pull fuses or relays? My Vette wouldn't rev higher than 4K when you didn't have the TPM in the wheels. Had to pull the traction control or one of the other relays to get rid of that.
03-11-2016, 03:16 AM | #41 | |
I actually drive it like this to and from the track. Probably have ~800 Street miles like this. No pulling of any fuses or anything. Just put it in track mode and hit the TCS button twice. Otherwise it acts funky braking and occasional throttle by itself. But that's more because of the difference in tire size I think tripping the wheels speed sensors.
2016 1SS A8
03-11-2016, 08:50 AM | #42 | |
マスタング = 遅い
