Old 03-22-2016, 11:27 AM   #15
KMPrenger
KMPrenger's Avatar
Originally Posted by ussj4brolli View Post
The timer starts if you go above IDLE no matter how hard you are breaking it
Well that's good to know. I haven't tried the 0 - 60 yet on my SS.
Those are some good times though! Best I recorded in my 2010 LT/RS with the A6 was 5.7 - 5.8, and that was with intake/exhaust/ported throttle body/manifold. Other guys with the V6 recorded better times, but that was the best I could do.
I think with as many mods as I had on the 6th gen V6, it would be very low 5s, if not a tenth below 5 sec with a perfect run.
Old 03-22-2016, 01:50 PM   #16
Marty McFlew
Drives: 17 SuperSport Camaro 6 on the Flo'
V8 and V6 test by Motorweek here....
http://video.mpt.tv/video/2365688683/
Marty McFlew is offline   Reply With Quote
Old 03-22-2016, 01:52 PM   #17
bballr4567
Drives: 2016 Camaro 1LT M6
Best I've done is a 5.7. Car does not like the WOT 1-2 shift at all.
bballr4567 is offline   Reply With Quote
Old 05-24-2016, 11:03 PM   #18
cellsafemode
cellsafemode's Avatar
Well, resurrecting this thread. Stock except for Trifecta tune. Had between half and 3/4 a tank of gas and a passenger in the car.
Second attempt, car was just flashed a day ago so the ecu may still be learning. This was after driving for about 30 minutes.
I tried using the android app torque to log speed and acceleration but it uses the phone's gps to log speed for some odd reason and gps speed lags and isn't accurate enough.
Guess i'll need to find something better i can run on my laptop to connect to the obd2 scanner to log some actual speed and data.
Old 05-24-2016, 11:32 PM   #19
keysersoze
keysersoze's Avatar
Drives: 16 Camaro
First and only 0-60 run I've done I got 5.3 seconds. This was just with mashing the peddle all the way down with no launch & wetish road so lots of spin. I believe I could get 5.1 with a good launch and good traction.
keysersoze is offline   Reply With Quote
Old 05-25-2016, 12:12 AM   #20
cellsafemode
I'm confident on a non heat soaked car and just me with much less fuel in the tank I'll beat 5.1 from idle.
Old 05-25-2016, 08:12 AM   #21
bballr4567
The 0-60 is timed using the actual wheel speed so I doubt that is right especially if you say there was lots of wheel spin.
I've got as low as 5.3 on a pretty good concrete launch but reset the damn timer when I stopped so didn't get a picture. I've got about 2700 miles on it so Im going to try again.
Old 05-25-2016, 10:37 AM   #22
Dcsimpkins
Dcsimpkins's Avatar
Drives: 2016 RS Summit White Black Stripe
5.3 here stock with a bit of wheel spin off the start
Dcsimpkins is offline   Reply With Quote
Old 05-25-2016, 04:06 PM   #23
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
When you guys post your times can you post temperature as well.. I have not seen better then 5.7 but I'm also in hot and humid Florida.
Dustya is offline   Reply With Quote
Old 05-25-2016, 04:14 PM   #24
gdespaux
Drives: 2016 Hyper Blue Camaro/2LT RS
Bone stock, I had 6.4 and 6.5 the two times i tried it :(
On fairly old blacktop road, about 88 degrees outside. And of course full tank of gas so...
What would be the ideal conditions to try this in?
Current:
2016 Hyper Blue A8 2LT RS
Previous:
2010 Victory Red 2LT
I've never had a V8
gdespaux is offline   Reply With Quote
Old 05-25-2016, 05:04 PM   #25
cellsafemode
basically quarter tank of gas
only the driver in the car, no cargo or passengers
cool temps outside (like 60ish i would think)
at sea level
No tire spin - so decent road condition not super humid
Level road
Strong tail winds to help push you
Old 05-25-2016, 05:08 PM   #26
gdespaux
at sea level
Level road
Well crap. I won't see 60 degrees here until next January
Besides that shouldn't be too bad to find an area like that. Thanks!
Current:
Previous:
I've never had a V8
Old 05-25-2016, 07:04 PM   #27
cellsafemode
Aren't you below sea level there? Might counter the slightly higher temps
Old 05-26-2016, 09:24 AM   #28
gdespaux
Definitely below sea level lol. I hope that does the trick!
Current:
Previous:
I've never had a V8
