Old 12-06-2015, 09:12 AM   #15
LesserO2Evils
GM repeat offender...
Drives: 16 2SS
BOOM goes the dynamite!!!
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15
INCOMING: ‘22 ZL1, Satin Steel. A10. PDR.
Ordered: 03/02/22.
LesserO2Evils is offline   Reply With Quote
Old 12-06-2015, 09:49 AM   #16
Merc
In The Circle
Merc's Avatar
I was wondering when we would see some slips posted? Post them to the V8 Fast list.
Old 12-06-2015, 09:52 AM   #17
big hammer
Drives: 2002 ws6
Mustang guys are saying that the slip car numbers don't match the numbers on the car
Bolt on 2002 ls1 Trans am--- 11.5 @ 121 (1.72) 2000 da
big hammer is offline   Reply With Quote
Old 12-06-2015, 12:46 PM   #18
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Congrats, read the updates on FB.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 12-06-2015, 12:54 PM   #19
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Were they there? Same slips, same car numbers, similar times in the 60 and 330 ft. I mean if they want a conspiracy, say both times were on DRs. Not the times aren't matching to the car because numbers/slip wise that is the same car.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Old 12-06-2015, 01:41 PM   #20
big hammer
Drives: 2002 ws6
Old 12-06-2015, 01:44 PM   #21
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
With the A8 and drag radials mounted on 17 inch wheels was the car consistent enough to be a good bracket car?
Buttonwillow 2:23.736
Sacramento Raceway 12.89 at 112 mph
Thunderhill 2:22.242
Cuda7050 is offline   Reply With Quote
Old 12-06-2015, 02:31 PM   #22
trz174
trz174's Avatar
Drives: Used to Drive Blue Camaros
Originally Posted by mcsoul View Post
So how close does this put the 2016 SS to the '14 and '15 A6 ZL1 off the showroom floor typical times? Is it about equal or a few 1/10's off?
Can not speak for the 14 and 15. Shortly after I got my 2012 ZL1 manual, I ran a best of 12.12 bone stock on street tires at the same track.
trz174 is offline   Reply With Quote
Old 12-06-2015, 02:33 PM   #23
trz174
trz174's Avatar
Originally Posted by bybcous View Post
Was an cel given with no tpms in that rear tire?
No cel, judt a low pressure warning.
Old 12-06-2015, 02:35 PM   #24
trz174
trz174's Avatar
Originally Posted by SUMMIT WHITE SS View Post
Awesome runs, what did you launch at, idle?
I would kill for negative DA...
Both launches were fron an idle. Loading it did not seem to help.
Old 12-06-2015, 02:42 PM   #25
trz174
trz174's Avatar
Yes. Full throttle launch without traction control is fastest and also consistent. Use air pressure for traction adjustment. It will also be a great occasional bracket car with TC on with either type tire combo - just slower.
Throttle lag takes getting used to for a good tree. Best RTs came from leaving at the end of the second yellow. The DR run was a pro tree for some unknown reason and a good indication of the lag.
Old 12-06-2015, 05:21 PM   #26
trz174
trz174's Avatar
We didn't have time to put the Weld wheels and M&H tires from the ZL1 on the front while at the track. So, we did a test fit and test ride today. The welds fit with about 1/8 clearance on the caliper. These are 6 piston Brembos so 4 pistons should be fine too. Tires were fine except they rub the rear of the inner fender well on the engine side when you turn all the way to the lock. Not likely something you would do on the drag strip. No issues with either rear or front on a 10 mile drive around town. Both wheels were the ones Weld recommended for a 2012 ZL1. I had them in the garage so I tried them. Here are the sizes:
Front: Weld RT-S, 17x5 with M&H 4.5/28.0/17 tires
Read: Weld RT-S, 17x9 with MT ET Streets, 295/45/17
Old 12-06-2015, 05:32 PM   #27
brutusvk
Drives: future 2016 SS
Great info. Thanks. Congratulations on the awesome times.
brutusvk is offline   Reply With Quote
Old 12-06-2015, 08:53 PM   #28
ISHLISS
Chevy & Ford Enthusiast
ISHLISS's Avatar
Drives: '21 Camaro LT1
Any pictures with the welds on?
ISHLISS is offline   Reply With Quote
