Old 10-07-2022, 05:07 PM   #407
Duramacr1
2Spdsy
Duramacr1's Avatar
Drives: 2021 Camaro LT1 A10
HEADS/CAM TIMESLIPS
Went out last night with the new setup . Name:  BA9DCFCF-8641-49DC-9494-A045372290E1.jpg
Size:  110.1 KB3480 raceweight. Da from 2100-1500.
FBO/E85/Dragpak/ stock ported heads/ Cam motion Titan 3 cam. The 60ft still sucks . Shift points were near stock. I got to back to the tuner and tell him to adjust shift points to 6700rpm. I don’t know how much it would help but my car feels like it’s short shifting every gear at 6350. Also, my converter is a Circle D 3X 3600-38000 stall. Is getting a bigger stall the only way to get a low 1.4 or high 1.3 ? This converter is already a little annoying to drive around. I can imagine a 4500-6000 stall. Anyway IT IS WHAT IT IS. I think it can be a little quicker but way off even from some fast Bolt on Cars . Don’t know how much a High Ram would help for ET? If anybody has any advise or info, I’ll take it . I went from 6.78 at 103 to a 6.65 at 106 . Tough to justify 6k out of pocket for 3mph increase. Hopefully the higher shift points will bring down the ET.
Duramacr1 is offline   Reply With Quote
Old 10-07-2022, 07:04 PM   #408
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Originally Posted by Duramacr1 View Post
Went out last night with the new setup . Attachment 11107413480 raceweight. Da from 2100-1500.
Great job Thomas, get out there and do it again.
Old 10-07-2022, 08:18 PM   #409
s346k
s346k's Avatar
Drives: like an old lady
shift rpm seems low. i shift my bolt on car at 6700.
what did you do with compression? id expect 5+ mph from a ported head/cam swap.
Old 10-07-2022, 09:27 PM   #410
Duramacr1
2Spdsy
Duramacr1's Avatar
Stock compression. Same size valves but solid SS valves . BTR .660 springs , GMPP lifters , Che trunion kit. All the head work was done by Westcoast Cylinder head. Good people over there. Thanks for the feedback. I wanted a little compression but the plan is to run nitrous so I left the compression stock. I guess extending that shift point will do the trick then. Thank you
Old 10-09-2022, 01:40 AM   #411
s346k
s346k's Avatar
if you have a dynograph, id use that as a gauge for shift points. otherwise you can use airflow to get a general idea of where it's laying over.
Old 10-09-2022, 09:33 AM   #412
Duramacr1
2Spdsy
Duramacr1's Avatar
I do have a dyno graph . It layed over at 6500 but it was a pretty hot day and didn’t make much power . Whe temps get colder im sure it will carry the power a little further .
Old 10-17-2022, 06:24 PM   #413
Dano
Dano's Avatar
Drives: 2022 Camaro 2SS 1LE M6
Car/Engine: 2022 2SS/1LE - 6SPD Manual
Top Thirty Class: Stock - Manual
Tires used on the pass: Continental Extreme Contact DWS 06+
Performance Mods (if any): None
R/T: .368
60': 1.961
330': 5.619
660': 8.353
660' MPH: 86.85mph
Name/Location of the track: Elk Creek Drag Way, Elk Creek, VA
Date of pass: 10/16/2022
Weather conditions: Temp 70.43 degrees, 30" Barometric Pressure, 40% Humidity, 3593 DA, 89.9% Relative Density.
2022 Shadow Gray 2SS/1LE, M6, PDR
Dano is offline   Reply With Quote
Old 11-15-2022, 10:14 PM   #414
Duramacr1
2Spdsy
Duramacr1's Avatar
Chipping away at my 1/8 mile time with c85
11/10/22 Name:  D4BACB99-1747-44EB-9754-ADEA9766978B.jpg
Took the car out again with much better Da last Thursday . Added 5 gallons of c85 and With 150DA . Car went 6.47 at 109. Here is the slip . Have a video as
well but can’t download it here . Never had any luck .
Old 11-15-2022, 10:37 PM   #415
laynlo15
laynlo15's Avatar
11/10/22 Attachment 1113975
Man that thing is hauling the mail. That's a high 9.90 ride. congrats
Old 11-12-2023, 10:48 PM   #416
Duramacr1
2Spdsy
Duramacr1's Avatar
2021 LT1 new PB
Size:  168.8 KBWow . I guess its been a year since I posted on here . Seems like the forum is slowing down nevertheless I’ll post my new PB for the car. It’s been some time and the car is now making
573/526 on the dyno N/A on pump E. Went from a 3800 stall to 4800 stall and added a GPI electric water pump just recently . Car ran consistent 6.1xx in the 1/8. Raceweight is 3275 and DA was 500.
Old 11-15-2023, 07:39 AM   #417
laynlo15
laynlo15's Avatar
Attachment 1140598Wow . I guess its been a year since I posted on here . Seems like the forum is slowing down nevertheless I’ll post my new PB for the car. It’s been some time and the car is now making
Man that baby is really hauling the mail. Congrats
Old 12-16-2023, 12:58 AM   #418
Duramacr1
2Spdsy
Duramacr1's Avatar
Still inching bit my bit . The N/A stuff is starting to get frustrating. Anyway I hit another PB but barely .6.07@115 in the 1/8. SBE 600rwp. It is what it is .
