02-16-2020, 10:16 AM | #1 |
Drives: 2018 ZL1 1LE Join Date: Nov 2019
Magnuson 2650 Fueling
I've been trying to decide what I want to do as far as fueling goes to make some decent power with the blower. I've narrowed it down to 2 options. The low side fuel with be upgraded in either scenario.
Option A +38% fuel lobe cam Option B Big Bore HPFP and +30 or +65 injectors Obviously option B is more expensive, but I'm wondering if option A would make the HPFP work too hard over time and fail and then I lose the motor I've seen a few do option A, but has anybody done option B? What kind of power did you make? |
02-16-2020, 10:33 AM | #2 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
What are your end goals as far as power?
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
02-16-2020, 10:55 AM | #3 |
02-16-2020, 11:21 AM | #4 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
EDFHobbies can help you out.
02-16-2020, 01:10 PM | #5 | |
02-16-2020, 10:13 PM | #6 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Option A will get you to 800whp no problem. Possibly even close to the 900s.
02-16-2020, 10:24 PM | #7 | |
Drives: 6th Gen NicKey Camaro & others. Join Date: Nov 2015
I understand your question, but this is option ‘A’ in my opinion. Just bolt ons with race gas will get you past the 800 rwhp Mark .
02-17-2020, 05:52 AM | #8 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
So, no fueling mods other than race gas mix? Any idea what it was at on 93? Those are the same mods in one of my options I am trying to choose from in another thread.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
02-17-2020, 05:57 AM | #9 |
Option A was a cam with a +38% fuel lobe to drive the LT4 HPFP.
02-17-2020, 07:02 AM | #10 |
Drives: 2017 ZL1 Join Date: Jul 2017
You won't need +65% injectors with the LPE Big Bore pump by any means. I have +30% injectors in mine with the LPE pump and they are out running the pump, even with a 38% lube and a low side system that stays above 80psi at WOT.
Also, speaking from experience, the LPE pump is great, but stay as far away as you can from their LT4 injectors!!!! We went through three sets and they were all DUCKING JUNK. In LPE's defense, they did buy them back when we proved that they were not working properly. |
02-17-2020, 07:10 AM | #11 | |
02-17-2020, 07:12 AM | #12 |
I was referring to the car in the video, what did it have done to aid in fueling?
02-17-2020, 09:19 AM | #13 | |
E85 at that power level can be difficult. If you're serious about it you really need to go all out on the fuel system. Low side, high side, cam and injectors. Remember E85 requires 30% more fuel which is already a pressure commodity on these engines. It's easier and cheaper to make more power by adding boost instead of E85 if that makes sense. If you're looking for 800rwhp I would do the low side and a cam. You can probably get by with just the low side upgrade but your high side will be pretty tapped out unless you overdrive the cam. |
02-17-2020, 11:45 AM | #14 |
Yep, I'm at about 852 on race fuel just with the Lt4 fueling and 1000 cc meth/water injection. I do have a boost a pump for the low side. I have the BTR stage 2 cam with 38 % lobe
Tags |
fuel, fueling, magnuson, tvs2650 |
