Old 09-19-2019, 04:52 PM   #15
JLSuperfly
JLSuperfly's Avatar
Drives: 2014 Red Hot LS3
Originally Posted by G8One2 View Post
LOL i just know how the vapor system works. I know that the canister vent valve is supposed to open when the ignition is off, closed when ignition is powered. I know that the fuel tank pressure sensor montiors the sealed tank pressure and commands the canister purge solenoid under the hood when pressure reaches a set limit, and pulls a specified amount of vacuum on the tank. Usually, if someone has issues filling the tank, its because the vent valve is not open and the back pressure created when filling the tank, causes the fill pump to shut off.
Say wut? You lost me after the first sentence.
JLSuperfly is offline   Reply With Quote
Old 09-19-2019, 04:54 PM   #16
JLSuperfly
JLSuperfly's Avatar
Originally Posted by SquawkVFR View Post
I didn’t know that, but for some odd reason...I stop on the first click...
I do too.
When it comes to rental however, I fill it until I see the gas start to overflow. I prefer not to get gas close to the airport where it is more expensive.
Old 09-19-2019, 05:01 PM   #17
ss_redrum
Drives: 2013 LS3 Camaro
Canister vent valve stuck closed.
Thanks for the response and sorry for the vagueness. Little more on it. The needle reads 3/4. On the pumps side it clicks at 10 gallons and I know that it needed more and figured it was the pump the first time it happened. I hit it again and gas spit out like it was overfilled.
2013 LS3 - Huron Speed Single Turbo - Tuned by me.
-Previous Setup- Texas Speed 1 7/8 LT Headers, no cats, xpipe, muffler delete, K&N Cold Air Intake, tuned by DynoSteve
Youtube |Instagram
ss_redrum is offline   Reply With Quote
Old 09-19-2019, 08:46 PM   #18
15RS2NV
Ponies are for girls
15RS2NV's Avatar
Drives: 2015 RS LFX Red Hot A6
When you are filling it up, fill it slowly. If you're having pressure issues, getting it to fill as fast as it can just builds up more pressure. Try putting it on the first notch while filling. (hope that makes sense)
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
15RS2NV is offline   Reply With Quote
fuel
