Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 11-05-2016, 03:46 PM   #1
suplex
suplex's Avatar
Drives: 2011 Coupe, 1LT, A6, No RS Package.
Arrow General Question About Tire Longevity...
I purchased my 2011 Camaro on 04/29/2011. It got delivered to the NJ dealership from PA so it had 263 Miles on it when I bought it (they told me about that and I was fine with it).
Currently, Five and a Half Years Later, I only have about 10,600 miles on it (I live close to where I work) and my Mechanic (VERY trustworthy, I've known him since High School) noticed some Dry-Rot on the tires and said I would need a new set by Spring of 2017.
I DO believe and Trust him, but should only 10,600 Miles of wear begin to show Dry-Rot on Tires? The tires are the O.E.M. ones that came with the car: P245/55-R18, BF Goodrich Radial T/A, they have a 620 Treadware Rating with a Traction/Temperature of A/B. It just seems like they should have lasted longer than that. I don't think it would be a Warranty issue, due to the age of the car anyway, but I wanted to post about it here and see if others have experienced any similar issues.
Never Underestimate The Power of Forums
suplex is offline   Reply With Quote
Old 11-05-2016, 03:51 PM   #2
jrhagen
Drives: Camaro
Your weather will kill tires. Feel lucky they lasted as long as they have.
jrhagen is offline   Reply With Quote
Old 11-05-2016, 04:50 PM   #3
RJT Impala
Stovebolt BluFlame 6
RJT Impala's Avatar
Drives: '12 2LT/RS, IBM; '20 Traverse Prem
Dry rot isn't associated with mileage. It's a function of tire age and exposure to environmental conditions--pollutants, sunlight, etc. I seem to recall something about 6 years from date of manufacture being the maximum that you should use a tire...could be mistaken, but that's what I recall. I've included a link that my provide some beneficial reading.
https://20somethingfinance.com/how-o...on-the-answer/
RJT Impala is offline   Reply With Quote
Old 11-05-2016, 04:54 PM   #4
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
The compound the tires are made of only last so long on sports cars!
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 11-05-2016, 06:49 PM   #5
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Like others have said, it doesn't necessarily depend on mileage on how they may dry rot. That being said, it you are having dry rot you may be able to get the dealership to knock some money off of a new set of tires based on mileage or lack their of on your original tires.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 11-05-2016, 07:03 PM   #6
NC_SS
NC_SS's Avatar
Drives: 2012 M6 Camaro SS (RIP)
Just because it's not being driven doesn't mean tires won't eventually crack and dry rot
Speed engineering 1 7/8 LTs, CAI inc Cold Air Intake, offroad connectors, Solo performance axle back with J pipes, tune, and in need of a driver mod LOL
NC_SS is offline   Reply With Quote
Old 11-05-2016, 08:29 PM   #7
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Black shoe polish.
CamaroFred is offline   Reply With Quote
Old 11-05-2016, 08:37 PM   #8
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
IBTM.
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 11-05-2016, 08:59 PM   #9
Originally Posted by Dizzy82 View Post
IBTM.
Your timing is impeccable.
Thread moved to the proper forum.
Old 11-06-2016, 08:47 AM   #10
DonM
Camaro #4
DonM's Avatar
Drives: 2017-Hyper Blue Metallic-2LTmanual
A lot depends on the tire, my brother's 2011 Chevy Silverado has low-mileage Michelin tires on them with like new tread BUT dry rot is starting to creep in heavy near the bead and shoulder of the tire. Tire rubber is only so thick and visible cracks are not a good thing, especially when you consider each crack is a weak spot that could cause the tire to blow. New tires every couple of years is cheap insurance.
Don M
Supercharged LGX + 6 speed manual = FUN!!
DonM is offline   Reply With Quote
Old 11-09-2016, 02:29 PM   #11
PK Auto Design
PK Auto Design's Avatar
Drives: 2017 Chevrolet SS 1LE
Its because of the age of the tires, not to do with the mileage of the vehicle. For as long as you have had the tires yes sir this is normal.
PK Auto Design is offline   Reply With Quote
