Vararam
Old 06-21-2014, 03:04 PM   #1
PJS45TH
PJS45TH's Avatar
Drives: 2012 SS 45th Anniversary Edition
ZL1 or supercharge my SS?
Pros and cons? I want more power but sure if its worth going down the aftermarket road vs trading in the SS. What was your decision process?
PJS45TH is offline   Reply With Quote
Old 06-21-2014, 03:08 PM   #2
jrhagen
Drives: Camaro
If you want all the other BS that goes with the ZL1, go that way. If not SC the SS.
jrhagen is offline   Reply With Quote
Old 06-21-2014, 03:15 PM   #3
Baer383
Baer383's Avatar
Drives: 2013 ZL1 Ashen Gray
The ZL1 has a stronger drivetrain than the SS,if you can swing it get the ZL1.
I don't have to know everything,I just need to know,what I need to know,when I need to know it!
MODS, a lot of money,a lot of parts,a lot of time,a lot of patience.
754 RWHP 747 RWTQ 93 Octane
http://www.camaro5.com/forums/showthread.php?t=347243
Baer383 is offline   Reply With Quote
Old 06-21-2014, 03:15 PM   #4
PJS45TH
PJS45TH's Avatar
Realistically what's it going to cost me to go the SC route? I would have it done. Not sure what else is needed above and beyond the SC.
Old 06-21-2014, 03:19 PM   #5
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Really depends on your goals and what you plan to do with the car.
Go with the AGP turbo kit as this will give you the greatest flexibility for future power bumps.
I bet you could get the AGP TT setup for about $8500 installed.
If you are absolutely set on SC, then you have to decide between centri and PD.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 06-21-2014, 03:23 PM   #6
PJS45TH
PJS45TH's Avatar
thanks. Not set on a SC. I'll do some research on the turbo.
Old 06-21-2014, 09:38 PM   #7
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
If you go over to the ZL1 forum you will get different answers there. GM really beefed up the ZL1 right from the factory. I started with the ZL1 because I like the mag-ride suspension and all the extra cooling and downforce built into the stock car. It is heavier but everything is more robust. I don't know anyone that went from an SS to a ZL1 that was disappointed in the trade. As a matter of fact there are a lot of ZL1 owners that had modified SS's. I recommend the ZL1 myself.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 06-21-2014, 09:47 PM   #8
jrhagen
Drives: Camaro
The signature from this post should answer your question. You can spend loads of money on a SS or a ZL1 and ultimately end up with basically the same car but the starting point is cheaper with the SS.
If the ZL1 is so great, what is the need for all the mods?
Old 06-21-2014, 09:48 PM   #9
MLAZ1990
MLAZ1990's Avatar
Drives: 2012 black camaro 2LS
I'd go with the ZL1. You get the power and a warranty!
SLP Loud Mouth 1 Exhaust, K&N CAI, RS Headlights, NightOwl V2 halo kit, ZL1 Grille, Custom 2LS Emblems, Green Footwells, GM GFX splitter, Ace Alloy Convex All Matte Black Wheels(20x9 & 20x10.5) wrapped in Toyo Proxe STII(255/45/20 & 295/40/20)
MLAZ1990 is offline   Reply With Quote
Old 06-21-2014, 09:52 PM   #10
Baer383
Baer383's Avatar
I haven't seen a modded SS on this forum that can compete with any modded ZL1,plus the drive train on the ZL1 is a lot stronger than the SS.
Old 06-21-2014, 10:18 PM   #11
jrhagen
Drives: Camaro
With enough money, anything, within reason, can be made faster than anything else. The only thing original on my SS is the M6. I have the ZL1 rear cradle and driveline for just the reason you stated.
My point to the OP is he already has a great platform, why lose value on it for trade-in. If he blows the LS3 or L99, he can drop a crate LSX under whatever supercharger he selects.
I swapped my out before I blew the stock engine and I am very happy with the results. I still have the stock engine on a stand in my garage for back up.
If the mag ride is that important get the ZL1. Everything else is a bolt on.
BTW, with the 20x10s on the front, you can't drop as far as a SS with coil overs.
Old 06-21-2014, 10:23 PM   #12
Baer383
Baer383's Avatar
My other post has a lot of merit to it.
Old 06-22-2014, 12:30 AM   #13
TheMeat
TheMeat's Avatar
Drives: 1973 Camaro
ZL1 will be worth more than a modded SS.
73 Camaro, 6.0 LS, Billet S485, E85, 4L80E.
TheMeat is offline   Reply With Quote
Old 06-22-2014, 08:27 AM   #14
MadOven
MadOven's Avatar
Drives: 2013 Rally Yellow SS/RS
You would have to give up the 45th edition. But you'd have warranty again. You'd have a car that has more power and was built to handle that power, over having a car that may require beefing up in areas as you add more ponys to it. Really up to what you want to get into. The ZL1 will be worry upgrade to a supercharged Camaro with everything built to support it. Or the SS that is your own 1 of a kind vehicle that.
2013 Rally Yellow 2SS/RS, Procharger I-1
MadOven is offline   Reply With Quote
