Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
View Poll Results: What is considered a ZL1 "bolt on"?
Blower case porting and snout porting is a "bolt on" 48 40.34%
Blower case porting and snout porting is NOT a "bolt on" 71 59.66%
Voters: 119. You may not vote on this poll
Old 12-01-2013, 10:15 AM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Poll: What is considered a ZL1 "bolt on"?
Just for fun let's see what the masses consider a "bolt on" with a ZL1 that has a factory supercharger. Merc clearly states that a "bolt on" is as follows: Bolt-Ons without Internal Engine Modification (e.g. modified airpath, headers, PCM-tune, aftermarket clutch, non-stock rear gears, skinny front tires)
OK...so now we are arguing over what does he mean by "modified air path"? My understanding is that a "path" is "a route or course along which something moves: the path of a hurricane.". So, air can be routed many different ways into the engine with various cold air induction systems and throttle bodies before the air enters the engine. Obviously, we must now define when something becomes "internal". Our ZL1 cars have a factory blower assembly with its associated metallic parts (snout, case, rotors). Airflow within the blower can be changed via porting the case & porting the snout. When does air enter the "engine"? Is the blower part of our "engine" because it is a factory installed part? Take the poll.
Old 12-01-2013, 10:47 AM   #2
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
I voted it as a bolt on. a supercharger is a bolt on power adder already regardless if its from the factory or not. when I think internal mods I think of parts within the block that cannot be seen or be removed with a few simple bolts. technically heads are bolt ons, just a lot more bolts
joes407 is offline   Reply With Quote
Old 12-01-2013, 10:54 AM   #3
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
I think it is not a bolt on. In either case I am not losing sleep over it.
Your stock or your not.
Trackman is offline   Reply With Quote
Old 12-01-2013, 11:05 AM   #4
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
Well normally most people think of bolt on's as external parts ! like my car everything is bolt on,but the cam...anytime you remove metal from a part its not a bolt on,its modified,changed to the point where it can no longer go back to what it was before.....a blower is not normally consider a bolt on,as of all the other parts that have to be installed on the car to go with it...that being said its not blk and white because they do make a complete kit that's all in one which could be considered a bolt on part....
The term bolt on's normally just means minor performance improving parts,but If you wanted to be silly about it,any part that has a bolt used with the installation of said part is just that,a bolt on part...heck a water pump is a bolt on part if it pumps more water than the part it replaces...
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 12-01-2013, 11:08 AM   #5
gen=5
gen=5's Avatar
yep stock or not !
Old 12-01-2013, 12:11 PM   #6
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
I love this answer but the sub-categories for 1/4 mile bragging rights has a bolt on section.
Clearly the CAI is not considered an internal mod and it affects airflow more than possibly any other mod. I feel the internal mods have to take place in the longblock to be internal. I think the reason they added the airflow thing is because if you bolt on a turbo or supercharger to a naturally aspirated engine you make so much gain no one else has a chance. Your blower and snout porting will give you slight gains but minimal compared to the boosting of NA engines. I say go for it. And besides, next is heads and a cam so you are probably going there anyway....lol.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 12-01-2013, 12:36 PM   #7
sycraft
COTW 5/06/2013
sycraft's Avatar
Drives: 2017 Corvette Grand Sport-Ho-Vette
BOLT/ON is more or less a ruling defined by LS1TECH of the guys who race, its nothing in the engine that touches oil so heads cam rockers valves, it only pertains to the engine not the trans or rear as far as a supercharger or turbo or nitrous then its forced induction. Basically from intake to oil pan, and the SC sits on top of the intake... So still a bolt on
2017 Grand Sport, Borla X Pipe.....Enough Said
sycraft is offline   Reply With Quote
Old 12-01-2013, 12:42 PM   #8
Justins00ss
Drives: 2000 viper blue flamed camaro ss
It is a bolt on. Weather you can except that or not is a different story. Deal with it! No different than porting a stock TB. Its not like changing heads or a cam.
2000 Camaro SS: TH350 RMVB FTI 4200, 236/240 cam, bolt ons, 9 inch, 150 wet kit, plus some other goodies, viper blue flames. M6 best time- 10.97 @ 128 1.58 60' best 60 1.52
Th350 best so far. 10.84 @126.3 1.55 60' BACK UP AND RUNNING!!!
Justins00ss is offline   Reply With Quote
Old 12-01-2013, 12:52 PM   #9
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
It always has been considered a "bolt on".
ZL1-V is offline   Reply With Quote
Old 12-01-2013, 01:20 PM   #10
jdsgn
Drives: 87 GN, 05 GTO
If you bought the snout pre ported and bolted it on does that change anything? Plenty of machine work goes into all the bolt on parts, just because you send one out to get ported doesn't change that it's a bolt on. All bolt ons effect airflow.
jdsgn is offline   Reply With Quote
Old 12-01-2013, 02:05 PM   #11
CamaroV6
Drives: Camaro V6 1LT Manual
Supercharger is a bolt on just cuz it comes from the factory on a LSA engine doesn't make it a internal engine part...
Where did you find this guy????
btw whats the point of all this are you saying that everyone on a bolt on list with the ZL1 that have ported snouts should not be there???or ppl that put bigger diameter intakes then what comes from factory should not be there??
or same with throttle body?????
CamaroV6 is offline   Reply With Quote
Old 12-01-2013, 02:19 PM   #12
Victoryred1le
Bupp Motorsports
Victoryred1le's Avatar
Drives: 2017 Summit White ZL1 A10
If you put a nick Williams 102 tb on your car, Is that not a bolt on? maybe this guy should just do that so it would shut everyone up. My company competes with redline so I know if Howard needs to he will put a stock one on and find power somewhere else so your argument is futile. I voted it a bolt on...because it is factory optimized equipment.
Victoryred1le is offline   Reply With Quote
Old 12-01-2013, 02:27 PM   #13
jessrayo
Speed Freak
jessrayo's Avatar
Originally Posted by CamaroV6 View Post
btw whats the point of all this are you saying that everyone on a bolt on list with the ZL1 that have ported snouts should not be there????
No, he is already on top of the list and wants to go faster.... but doesn't want anyone else calling foul....lol. Just do it!
Old 12-01-2013, 02:34 PM   #14
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Its a bolt on not internal.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
