TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 07-28-2017, 03:15 PM   #1
Dbunch9
Drives: 2010 Camaro 2SS
Motor oil for trans fluid?
So my brother in law just redid a bunch of stuff in the trans of his neon srt4 and said he read people were using Mobil 1 10w-40 high mileage non synthetic for trans fluid with good results. Does that sound like a bad idea for a tr6060? My trans doesn't shift smooth and I'm not sure whether it's the shifter (POS hurst), synchros or bad 1/2 gears so I'm trying to look for a cheap fix and I see people say change the trans fluid first. Any input?
Dbunch9 is offline   Reply With Quote
Old 07-28-2017, 03:30 PM   #2
Synner
Drives: cars
That's a great way to grenade your transmission. You can't compare completely different transmission fluid requirements. These require ATF style fluid for viscosity reasons.
Synner is offline   Reply With Quote
Old 07-28-2017, 03:49 PM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
another
must be Friday!
you want serious advice? (I could say just sell the car but that would be mean) Royal Purple...don't look back...good luck
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 07-28-2017, 05:25 PM   #4
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 07-28-2017, 05:49 PM   #5
Dbunch9
Just thought I'd ask lol glad I did
Old 07-28-2017, 09:22 PM   #6
Donald
Drives: Just a dream...
This sounds almost as bad as the SRT4 owner that cranked the engine without a filter to get all the old oil out...
Donald is offline   Reply With Quote
Old 07-28-2017, 10:24 PM   #7
Dbunch9
Old 07-28-2017, 10:32 PM   #8
frankwjr
frankwjr's Avatar
you also need to do a clutch/brake fluid bleed/exchange...major shift improvement..
Old 07-28-2017, 11:09 PM   #9
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
I know of a few that run oil in their transmissions
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 07-28-2017, 11:29 PM   #10
dreksnot
dreksnot's Avatar
Well, I'll be a monkey's uncle...
Old 08-01-2017, 08:55 PM   #11
05SilverStreak
05SilverStreak's Avatar
Drives: Black aSS 2011 - L99
Is there a video of the pan coming off and changing the filter too? Basically showing the whole process?
Staying stock and loving it............
05SilverStreak is offline   Reply With Quote
Old 08-01-2017, 09:49 PM   #12
Bo White
Bo White's Avatar
I know right lol!
They arent tr6060 trannys though.
Totalled:
