03-15-2021, 11:09 PM | #1 |
Drives: 2017 Camaro 2SS Join Date: Mar 2021
Coilovers needed? Purchased new tires/wheels
Hi All,
I own a 2017 Camaro 2SS. Today I purchased MRR M755 WHEELS GLOSS BLACK 20X10 & 20X11 wheels & will be getting EXTREMECONTACT DWS 06 PLUS Tires (275/30 ZR20 & 305/30 ZR20). My question is... since the car comes with Magnetic Ride Control, am I able to just install these new wheels or will I need to get coilovers? What is recommended and usually preferred. Thanks! I heard that coilovers disable the MRC which sounds not worth doing, and honestly I love my changeable features and the car rides well enough. |
03-16-2021, 07:22 AM | #2 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
You can install no problems. If you want to kick the suspension up a notch look into the 1LE kit sold by GM.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
03-16-2021, 10:06 AM | #3 |
Drives: 2017 Camaro 2SS Join Date: Jul 2016
You paid for MRC so I'd def keep it. Go with some bmr springs and sways and call it a day. I've got the exact same wheels except I downgraded to 19's for weight savings (~9 lbs per corner!) and better ride as I don't have mrc. The 1" drop from the springs works perfectly with the smaller wheels but also looked great on the oe 20's.
2017 2SS A8 TSP LT's, ported msd/95 mm, e85
03-16-2021, 10:40 AM | #4 |
youll be fine
03-16-2021, 08:42 PM | #5 |
Thanks everyone!
03-16-2021, 09:14 PM | #6 |
Tampa Bay Camaros
Drives: 2017 Krypton Green 2SS Join Date: Jul 2011
I just installed 5th gen ZL1 wheel replicas with continental Extreme DWS 06 tires. 285-30 fronts and 305-30 rears. I have MRC. Absolutely no issues, no rubbing.
20x10 front wheels and 20x11 rear. Basically plug and play. Sent from my Note 20 Ultra 5G using Tapatalk
Me and wife, in order
2011 2SS SGM 2013 2SS Hot wheels vert 2016 C7 DSOM 2012 2SS yellow vert 2017 2LT Krypton Green 2018 2LT Hot wheels crush 2020 2SS Shock vert. 2017 2SS Krypton Green coupe |
04-10-2022, 04:21 PM | #7 |
so i just bought 275/30/20 on a 20x10 for the fronts and 315/30/20 on 20x11, will i have a terrible overlay with wheel to tire on the 275/30's on the 20x10, im just worried that the rim will poke out far.. will i be OK?
04-10-2022, 08:05 PM | #8 | |
In itself a 275 width tire for a 10" wheel would be fine, but wheel poke heavily depends on the offset that you didn't mention.
04-10-2022, 10:50 PM | #9 |
my offsets for the 20x10 are +23 and for the 20x11 are +43
(btw the tires are the michelin pilot 4S) Last edited by phxsec; 04-10-2022 at 11:20 PM. |
04-10-2022, 10:53 PM | #10 |
cause i originally wanted to get 285/30/20 for the 20x10's but they didnt have them in stock until june/2022, and so then i opted and got the 275/30's for the 20x10, should've i gotten 275/35's or will the 275/30's work? sorry for trying to hound for answers.. its my first time going for a staggered setup and wasn't prepared to be told my 285/30's weren't gonna be available..
04-11-2022, 08:42 AM | #11 | ||
If this is the case, the new fronts are 4% shorter than stock and the new rears are 0.7% shorter, so you're looking at a 3.3% difference you are about to introduce between front and rear (see for yourself at https://tiresize.com/comparison/). Based on other members' experience, the threshold where stabilitrak and ABS start signaling an issue is around 3%. You're cutting it very close and the setup may just barely work or may not, I'm not a tire and wheel shop and never ventured beyond this threshold myself
04-11-2022, 09:18 AM | #12 |
yes, i originally had the 245/40/20 on my car (square setup), good news is that the tire guy told me that if i did have problems with my 275/30's that i could return them within 30days and get the 275/35. i rlly appreciate all this input it is very helpful as you already know i'm new to the staggered look ! i'll try to figure out to post a picture of them when both sets are on !
04-11-2022, 02:02 PM | #13 | |
04-11-2022, 02:14 PM | #14 |
will i have any rim poking out with the 275/30/20 on the 20x10 +23? tire people told me today that i can get my 315's mounted today but i have to wait until the 275's ship wednesday to get them mounted.
Tags |
camaro, coilovers, tires, wheels |
