03-19-2018, 02:49 PM | #43 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
Owning one of these cars isn't a "poor man's" game either. I'm still blown away by the kind of money folks have to spend on brand new $40k-100k cars that are already fast, subjectively speaking. Obviously there are tons of fantastic paying jobs out there now, so that must be part of it. I think these things drive awesome bone stock. I appreciate you putting a REAL price on what these things cost. I like the idea of staying NA and doing parts at a time as money comes along.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
03-19-2018, 03:52 PM | #44 |
Drives: SS 6 speed of course Join Date: Jan 2016
also that mean cam sound for NA, and weight and ring gap... and simple.
03-19-2018, 04:34 PM | #45 | |
Also on a DI engine and FI, all air is already ingested and being compressed when the fuel is being put in. So 6 PSI of boost say 30% greater air charge is being compressed 11.5 to 1 as the fuel is going in. Total combustion chamber PSI will be much higher (higher head) vs a liquid induction via the intake. That is a lot more head vs a N20 where it is mainly liquid by weight and does not vaporize fuller till near or past TDC.... The flow rate of a liquid is roughly the square root of the pressure delta. Long story short, I'm not surprised that a FI engine has far more dynamic compression than a liquid inject over NA engine, leading to higher head pressure and lower delta of rail to chamber => less fuel flow into the engine per any given HP.
03-21-2018, 10:38 AM | #46 | |||
Drives: 2016 CAMARO 2SS Join Date: Apr 2017
But most of the 6th gens I have seen both H/C , fbo and stock don't require a progressive controllers. I haven't seen Prays H/C setup on dope yet!! His NA setups seem to make a good deal more power so that maybe come into play. Quote:
You pull enough timing and have enough fuel she tends to be much happier longer. I haven't seen a FBO run 9's on bottle. Have seen some H/C cars do that though. I think like anything else you could get away with doing a ZL1 pump up to a certain point but I think you would be pulling the pin on the grenade like KING said with a pressure drop on the hit or anywhere through the curve. Wouldn't take much especially on stock pistons. At that point why take the chance.. Quote:
Most nitrous people here or the ones I see run the bare minimum on 150hp. Hell I have see guys that don't gap the plug and run stock tunes with no timing pulled. But I don't see them running low 10's or high 9's either. What you can get away with and what is safe are 2 different deals. "LEANER IS MEANER" blows chit up! But does work from time to time. Just like the stock LS motors that people boost. Some guys can run 8's some run 9's and some blow up in the 10's. Some have luck with stock rod bolts some don't, some regap rings to go fast and some don't.... some have lived not doing it and some haven't. I lived on nitrous for many many years.. I have gone both directions on both burning up motors half ass because it was the cheaper route and I have pushed stock parts with beyond limits with enough safety aka done correctly. If someone is planning on running low 10's or high 9's on the stock bottom end on nitrous then a dedicated is the way to go.
2016 SS A8 STOCK 12.35@113.6 DA 1956
PRAY E85 TUNE,PRAY PORTED IM/TB,ROTOFAB DRY, DRAG PACK 11.33@121.8 DA 1248 PRAY PORTED MSD, 2" TSP LT's 11.38@122.4 DA 3664 GFORCE DRIVESHAFT,LME 174 T-STAT,ATI UDP up next... Last edited by TEEZYSS; 03-21-2018 at 10:59 AM. |
Thread Tools | |
