03-11-2018, 09:37 PM | #1 |
2018 1LE, NASA Instructor
Drives: 2018 Camaro SS 1LE Join Date: Jan 2018
Confirm that this Dexos2 5W-40 Motul 8100 X-Clean is good for Track and Street
There seem to be so many threads indicating that it is hard to find a Dexos2 0W-40 or 5W-40 oil that meets both street specs as well as the High-Performance/TrackPrep Guides.
I seem to have no problems finding them readily on Amazon, but am doubting myself, based on the comments here. Can someone confirm that the oil below is good to go for street and track for a 2018 SS-1LE? |
03-11-2018, 09:52 PM | #2 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
It’s the only oil I have used in my ‘17 1LE.
I have 15,000 miles, 150+ AutoX runs, and about 20 Track days. Every change has gone to Blackstone and they have all been great.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
03-12-2018, 10:27 AM | #3 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Yes that oil is good for the street and track. It has the Dexos2 certification.
03-12-2018, 01:18 PM | #4 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
It's also what I run in my car.
03-12-2018, 03:02 PM | #5 |
Drives: 16 ngm ss Join Date: Jan 2017
Valvoline mst as specified in the Owners’s manual is readily available at my local Napa and often on sale for about $5.50 qt which is much cheaper than I’ve seen Motuls go for.
03-12-2018, 03:24 PM | #6 |
Drives: ZHP, Alfa 4C, RAM, X5, 17SS1LE-sold Join Date: May 2017
03-12-2018, 09:24 PM | #7 |
Would the dealers do the oil change using Motul if I buy/bring it to them? I'm challenged to do oil changes myself (live in Condo with a bunch of rules).
03-13-2018, 12:11 PM | #8 | |
I'd find a reputable shop then at least usually you can watch. |
03-13-2018, 05:59 PM | #9 | |||
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
I recently got delivery of my 1SS 1LE and also plan to use the Motul 8100 X-Clean. It is apparently top notch stuff.
There is some Oil Testing "Maniac" from Poland, whom I watch videos and read summaries of. Have a look here to see more and make sure you read the comments / text: and here: And here: Here is a link to the table with all oils he tested and his findings: https://docs.google.com/spreadsheets...pgg/edit#gid=0 I hope you find this useful... |
03-13-2018, 10:43 PM | #10 |
ˆˆˆˆˆˆ
Cool info. Thanks. |
03-14-2018, 09:27 AM | #11 |
Drives: 2017 2ss, m6 Join Date: Jan 2017
Just remember that dexos2 is specified as having more heavy metals and other additives that are known to degrade catalytic converter life. The new recommendation for the 0w40 is in my opinion only for the specific Mobil 1 listed...not all dexos2 oils. If you are going to run a dexos2 oil full time I would look at running a true performance oil; you're going to hurt the cats...but you'll get better protection along the way. Just my .02
03-14-2018, 11:54 AM | #12 | |
Drives: 2019 CLA 450 Mercedes Join Date: May 2016
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red 2014 Lincoln MKT EcoBoost (The Bus) |
03-14-2018, 06:17 PM | #13 | |
How often do you change the oil? Which filter do you use: AC-D PF64 ? |
03-14-2018, 08:08 PM | #14 | |
If Dexos2 0/5W40 is not available, two alternatives are mentined. And only one of those (less desirable alternatives - Mobil 1 15W50 - is there a need to switch oils after the track event. Dexos2 0/5W40 is by implication OK to keep being used on the street as well. Below is the exact text from the manual: |
