Old 03-11-2018, 07:47 AM   #1
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
Meth % ?
Ok I understand meth cools and adds octane and allows you to run more timing to make more power and all that, also its being used to make up for the fuel systems short comings. But why do some use straight meth some use 50/50 meth/water ,some use the -20 washer fluid that is like 30/50 meth /water. I also understand about the fire issues with straight meth. I guess Im wanting to know about the power increase. Does straight meth make more power with more issues? Does 50/50 make the same power but no fire issues? What percentage to use and why?
DapperDan is offline   Reply With Quote
Old 03-11-2018, 09:35 AM   #2
JFM-jr
JFM-jr's Avatar
My understanding is (and I could be wrong feel free to correct me) pure meth is more for the fueling side and light mixes like windshield washer is more for cooling IAT's only.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 03-11-2018, 11:12 AM   #3
DapperDan
DapperDan's Avatar
So if you have the lt4 fuel system and did the 50/50 meth/water would you make the same power as straight meth or would the 50/50 mix make the octane lower and it wouldnt make as power as straight?
Old 03-11-2018, 11:38 AM   #4
Omega
Drives: G8
From what I understand, running 100% meth gives you the octane boost to make more power but you need keep on top of it. Make sure it hasn't gone off or you run out while using it, have your tune setup to kill timing if the IATs go nuts. 50/50 or anything less is just to cover your butt a bit, it will just cool the IAT, keep the timing the same or only slightly more.
Sent from my Pixel XL using Tapatalk
Omega is offline   Reply With Quote
Old 03-11-2018, 11:40 AM   #5
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
I watched this video and it explains all stages of meth and power.
http://www.dragzine.com/tech-stories...injection-101/
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 03-11-2018, 02:11 PM   #6
Omega
Drives: G8
FYI, only Alkycontrol is rated for 100% meth. With the plastic push to fit hose you're limited to 50/50
Old 03-11-2018, 02:20 PM   #7
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I was running 65/35, changing to 50/50 VP Alky.
Old 03-11-2018, 02:31 PM   #8
DapperDan
DapperDan's Avatar
So the kit from snow for the gen 6 camaro with the plate setup for the nozzle and the braided lines wouldnt work with straight meth?
Old 03-11-2018, 03:41 PM   #9
1le32907
Drives: Summit white 1le ss
Nope will kill your pump. Alky is good and stands behind their work. I run straight meth last a while easy enough to refill just have to order 5 gal containers all the time. I run it for alittle protection and alittle timing.
1le32907 is offline   Reply With Quote
Old 03-11-2018, 03:46 PM   #10
laynlo15
laynlo15's Avatar
I run the AEM
Old 03-11-2018, 08:31 PM   #11
kttxz06
kttxz06's Avatar
Drives: '18 Zl1. '18 GT350.
I'm not a tuner so I won't speak on behalf of Matt Sorian, but there is a reason why I am running 100% meth over a mixture. If he says 100% meth is better than that Snow shit mixture crap out on the market, then I believe him. Plus, it's methenol in it's purest form and I'd prob say it keeps the IAT's a tick lower than a mixture does. But, I'm just guessing here. I'd never run a mixture. Just run 100%. Buy you a 5 or 10 gallon VP pump can and keep that sucker full like I do and filler up.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
kttxz06 is offline   Reply With Quote
Old 03-11-2018, 08:32 PM   #12
kttxz06
kttxz06's Avatar
Stay away from the Snow kit and run the Alky kit. You've been warned.
Old 03-11-2018, 08:39 PM   #13
ZNix
Drives: 1987 Buick Grand National
100% meth. Tune for the added fuel/octane. Only thing you can do is run a fail safe like an AFR alarm (probably too late) / boost / timing cut. If you can't handle the upkeep of a meth injection and need to tune for failure, forget it. I hear that argument against meth, way too often.
ZNix is offline   Reply With Quote
Old 03-11-2018, 10:39 PM   #14
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
Been running alky meth 100% kit for a year now... pretty problem free I had one issue but it was nothing to do with kit design was a install issue. FYI I daily drive it 25k miles in the last year.
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/
Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA
Supercharged with Overkill Superchargers http://www.v6superchargers.com
Dustya is offline   Reply With Quote
