02-26-2018, 03:06 PM | #1 |
Drives: Lowered 98 sliverado, 18 1SS 1LE Join Date: Feb 2018
Rubber burning smell
Hi all just got my 18 1ss 1le and its a blast! Only issue is this melting/burning rubber smell after a get back from a drive. I'm at 200 miles now and it seems to be going away. Not sure if this is normal as this is my first new car. I have been following the break-in procedure outlined in the sticky.
Thanks in advanced! |
02-27-2018, 08:30 AM | #2 | |
Pop the hood and run it, look for anything odd (around exhaust) Good luck.
2016 Camaro 1SS, Red Hot, K&N Blackhawk intake, Whipple Supercharger, 3.125 pulley, Kooks 2" long tube headers, High flow cats, secondary cats delete, Mishimoto catch can, P3gauge, Lots of dress-up crap that don't make it go any faster.
Car Journal http://www.camaro6.com/forums/showthread.php?t=490975 SC build http://www.camaro6.com/forums/showthread.php?t=492656 Drive, Ride, Fly It Like You Stole It GO BIG OR GO HOME |
02-27-2018, 09:00 PM | #3 |
I took it out again for another 90 miles. Still smelling it. I checked around the manifolds didn't see anything too close. I guess I'll check under the car when I get the chance.
03-02-2018, 08:54 AM | #4 |
I had that issue when also it was the air condition belt rubbing on the wiring harness, I just moved the wiring harness over all fixed.
03-03-2018, 01:42 AM | #5 |
Drives: 2017 ZL1 Join Date: Oct 2016
yup, a few have said that wiring harness can contact the belt - check all around it and make sure. Mine was pretty far away..
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
