03-30-2017, 04:26 PM | #15 | |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
03-30-2017, 05:27 PM | #16 |
1959 Chevy Apache 4X4
Drives: 2017 ZL1 Join Date: Feb 2016
I took the Dremel to it. I cut off the 2 end humps. The S7 fits like a glove now. I've I were to do it all over again, I'd put a piece of metal where I want the cut to end, thus protecting the uncut surface. I have a few circular marks.
The only people that will ever notice would be a backseat passenger who is looking for it. I don't anticipate that But, I will be on the lookout for a replacement. If I find some, I'm going to pick up a few. One to have as a complete original, and 1 or 2 to perfect my cut
2017 ZL1 garnet red/A10/nav/pdr/sunroof/CF hood insert
1100 2-1-17 2000 2-14-17 3000 2-15-17 3000 TPW 3-13-17 3300 3-6-17 3800 3-13-17 4B00 3-13-17 4200 3-15-17 4800 3-22-17 5000 3-27-17 6000 3-28-17 |
03-30-2017, 06:10 PM | #17 |
Drives: 2017 ZL1 A10 Join Date: Nov 2009
03-30-2017, 09:34 PM | #18 |
Lol.
03-31-2017, 07:06 AM | #19 | |
I may try modifying mine with heat. I have a Harbor Freight plastic welding tool which should allow me to do some reshaping. I'll let you know how it goes. |
03-31-2017, 08:33 PM | #20 | |
Drives: 2016 Camaro Convertible 2SS Join Date: Nov 2016
04-22-2017, 06:34 PM | #21 |
Drives: Garnet 2 LT, black wheels, A8, V6 Join Date: Apr 2016
I received my Galaxy S8 and fits in the charger without a case.
04-22-2017, 11:10 PM | #22 |
I got mine the other day, it fits, a little tight. I actually cut one of the bumps on one side and it fits better now.
03-02-2018, 02:03 PM | #23 |
Drives: 2016 Camaro 2SS ... 2024 Camaro 2SS Join Date: Aug 2016
03-10-2018, 06:50 AM | #24 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
How are you guys charging your phones!? I p ullef the rubber piece out, (super easy) took my phone out of its case, and obviously fits fine. Phone still won't charge, but What I'm reading is people are getting it to work?
07-28-2018, 12:54 PM | #25 |
Drives: '16 2SS M6,'96 WS6 M6 Join Date: May 2009
I recently installed the new charging pad from GM, I made a how to video for those interested....
https://youtu.be/Ktt8jmr0lDo
'16 NFG 2SS M6,SW NPP compatible axel back, black center stripe, black non-split rims
'96 Black WS6 TA - M6, Pro 5.0, Baer Track kit, Corsa Cat-back, Bilstein shocks '99 30th anniv TA vert #988- M6 |
08-01-2018, 05:57 PM | #26 |
Drives: Too many to list Join Date: Dec 2011
I got around to putting mine in today. It’s quite a bit thinner than the original.
It’s the easiest install I’ve done in a while. There’s certainly no need to remove the bottom seat cushion to prop up the center console. It’s more work to remove the seat cushion than it is to use a plastic panel tool and gently push the seat cushion back to lift the console up. Sent from my iPhone using Tapatalk Pro |
08-01-2018, 10:37 PM | #27 |
I finally got ahold of an iPhone 8 today from a friend, charges great! Can’t wait for the new phones to come out next month
08-08-2018, 08:36 PM | #28 | |
Drives: 2SS - Black Join Date: Oct 2009
