02-19-2021, 02:56 PM | #1 |
Drives: Chevy Camaro 2015 2SS RS Join Date: Feb 2020
Is Air Dam necessary if you have a front splitter?
just as the title said, is there a purpose keeping the air dam once you install the splitter?
02-19-2021, 03:10 PM | #2 |
Took mine off a looonnnggg time ago. lol... Looked crappy so I removed it and never had any issues..
02-19-2021, 03:16 PM | #3 |
lol sounds good, mine was breaking off so I installed a splitter and didn't bother putting it back on
02-19-2021, 03:26 PM | #4 |
Yep, mine was looking tacky so I pulled it off even before I put a splitter on there. Some folks will tell you it is there to deflect air away from the engine compartment under the car, but it is so flimsy I couldn't see that. lol..
02-19-2021, 03:58 PM | #5 |
Drives: 2SS/RS Join Date: Sep 2008
Air dams work at high speeds but most of us will never drive fast enough to need it. Mine came off after a couple years and never bothered putting it back on.
02-19-2021, 04:47 PM | #6 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
I'm just looking at this as what are you talking about? Is it the rubber piece that runs along the front bottom of the car in the front. I have had mine on since I bought the car and it is still in good shape. I have a splitter on my car from day one. I'm putting a new SLP splitter on. But if I don't need it I'm going to take it off.
THXS
02-19-2021, 06:10 PM | #7 | |
02-20-2021, 04:41 AM | #8 | |
Drives: 2010 2SS/RS, VR ext/Blk Int Join Date: Jul 2012
02-20-2021, 06:02 AM | #9 |
I left it on with my other splitter and never had any problems with it. And like I stated above it is still in good shape. The installation of the SLP splitter shows leaving it hooked up on each end and letting it hang down while installing the splitter. When I get around to installing the splitter I'll make up my mind weather to take it off or just leave it on.
02-20-2021, 07:01 AM | #10 | |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
02-20-2021, 07:26 AM | #11 |
Drives: 2013 Camaro 2SS/RS Join Date: Aug 2020
The one on my car acted as an effective snow plow and has ripped off twice in two years. Once by the snow and once by a curb while parking one day. I don't have a splitter for the same reason. For me they are non functional. However, for the Grand Nations there is a plastic intercooler scoop that is most functional but because the GNs ride higher there is no snow scoop issue to be had, in fact where with the Camaro I have ripped two off in two years the GN still has the factory intercooler scoop intact.
02-20-2021, 09:45 AM | #12 |
Nope, pulled that off before I put on the splitter and threw it away. I also do my own oil changes and was tired of that being there and having to lift the car higher just to get under that piece.
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill. |
02-20-2021, 10:41 AM | #13 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
The idea is the less air going under a vehicle, the better the mileage, at least for trucks. When racing, you really want to limit air going under the car as much as possible. On the ZL1, the air dams are only at the corners. If you take it off, you won't notice any difference.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. Last edited by CamaroCracka; 02-20-2021 at 10:52 AM. |
02-20-2021, 10:44 AM | #14 |
Drives: 2012 SS Join Date: Feb 2016
Took mine off when I installed my slp splitter. Looks better & noticed no difference in anything.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
Tags |
air dam, install, splitter |
